12-11-2017, 08:51 PM | #1 |
Troubleshooting help
Ok guys,
I just got the old girl up and running again so I can use her as a daily driver. I was going through things and ended up replacing the starter (it was weak and grinding) and the alternator (bearing shot and barely producing a charge). Before I replaced all of this stuff early morning a couple days ago I pulled out of the driveway and lost all power, headlights, radio, engine died. Very strange. Within 10 seconds it comes back and I restart and park it at home for the day. This weekend after replacing all the above stuff I drove her around the back roads hard trying to see if she will die again. I could not get her to duplicate the problem. This morning I start her up and leave. Halfway down the on ramp to the interstate it does it again. Lose power, all lights, radio. I pull over, and call wife. For grins I put on my battery jump starter and notice the battery is a zero volts. Nothing, Nada. I run home and get a backup battery I have for the camper to try and get her home. Hook it up and she starts like normal. I'm about to drive away and before I shut the hood I notice sparks aft of the starter. I quickly unhooked the battery and pulled her home. Tonight I get home and try to find where the sparks are coming from. I crawled under the truck and looked all over the starter area. I don't see a thing. I hooked up the battery from the top and could see some sparks but can't pin point the exact spot. I don't have a helper until this weekend to have someone connect the battery while I'm under there. What could be causing this short? I have new wiring throughout the truck, kits from Classic parts, and the start wiring is very clean and precise. I wire airplanes for a living so I know wiring pretty well. Where could this short be? There aren't any wires around there and I can't find any burn marks. Could the starter be shorting directly to engine? This only happens when the battery is hooked up. Has anyone seen anything like this before? Cheers.
1966 Chevy C-10 350 Engine 700R4 |
12-12-2017, 06:23 AM | #2 |
Re: Troubleshooting help
grounding problem? body ground strap missing/broken? wish I had more, I'm not much of a wiring guy.
12-12-2017, 11:22 AM | #3 |
I was thinking about grounds too, they are an issue with our trucks, but would a ground strap cause a short that is a direct path from the battery? I'm asking, I don't know.
12-13-2017, 12:02 AM | #4 |
60-66 Nut
I would be suspect of the starter.
12-13-2017, 12:34 PM | #5 |
My concern would be the starter as well. Even though it's new quality control isn't what it use to be. I'm sure it has a warranty. I'd pull it off and bring it back to swap out.
12-13-2017, 01:11 PM | #6 |
This may sound crazy but the starter is now the main grounding circuit. Look at how it is actually bolted up. Did you use anti-sieze on the bolts? Is the new starter painted?
Honestly this is something that happened to me on another GM starter. |
12-14-2017, 12:48 AM | #7 |
If you suspect the starter proper disconnect the cab feed & other wires from the solenoid, re install the Positive cable & re attach the cable to the battery. If it is the starter it should spark then & should eliminate the rest of the wiring.
12-16-2017, 07:51 PM | #8 |
And, it was the starter. Thanks guys. I was leaning toward that but it's always nice to get more input. I appreciate it.
12-18-2017, 10:27 PM | #9 |
The problem here is china chit. lol
12-18-2017, 10:38 PM | #10 |
Yep
Posted via Mobile Device |
Thread Tools | |
Display Modes | |
