02-14-2018, 10:16 AM | #1 |
blinker question
67 c10.
Got the blinkers to work along with the brake lights the other day. Question is, they don't make any noise when they blink, and they don't automatically turn off after a turn (I have to manually move the stock back). So is this normal? Also, my hazard lights don't work. I'm thinking maybe something is amiss and the two are related? thanx |
02-14-2018, 04:21 PM | #2 |
Re: blinker question
Not sure about the sound issue, but the the canceling might be a canceling cam issue inside the column.
https://www.youtube.com/watch?v=20qVTf8FI7Q
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
02-14-2018, 04:25 PM | #3 |
I had an issue once and i swapped the hazard flasher relay with the turn signal flasher relay to help me troubleshoot.
Might need to replace the flasher relay, super simple, you can get one at any auto parts store. The part at AutoZone is https://www.autozone.com/electrical-...7281?location= Not sure exactly what your issue may be, but I had an problem recently that might help you along in your search for a solution. Check out my thread at http://67-72chevytrucks.com/vboard/s...d.php?t=575923
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels 1976 K20 crew cab, 350/Ranger/SM465/NP205 Last edited by Benjamin; 02-14-2018 at 04:30 PM. |
02-15-2018, 11:13 AM | #4 |
thanx for the responses. going to check this out on my day off.
love the "blinker fluid" top off |
02-15-2018, 04:44 PM | #5 |
The not canceling and not working hazards are probably a bad turn signal switch in the column. On my 75, both come off the same unit. The silent flasher could be an electronic one.
Thread Tools | |
Display Modes | |
