Old 05-15-2018, 01:52 PM   #1
3757chevy
3757chevy's Avatar
Rear Shock Relocation Bracket (my version)
Thought I would share my latest project on my 67 step side rear shock brackets . I saw these first back in 2011 http://67-72chevytrucks.com/vboard/s...d.php?t=451200 but I had an Idea that I could make them more appealing to the eye and with less material.
'67 Stepside(since1997)...'72 K5 Blazer(since2013)...'35 Pickup(since2020)...MIKE
3757chevy is offline   Reply With Quote
Old 05-15-2018, 01:53 PM   #2
3757chevy
3757chevy's Avatar
Re: Rear Shock Relocation Bracket (my version)
The first picture is the original plans that I borrowed . Saved it in the paint program , modified it to my liking and printed up my plans. The best part is that I was able to use a piece of scrap 2" X 2" tubing. Now all I have to do is drill out the rivets and mount them up.
Old 05-30-2018, 10:44 PM   #3
3757chevy
3757chevy's Avatar
Got some lower brackets from member TXLSX . They will replace my repaired (poorly) stock lower brackets.
Old 07-01-2018, 11:50 PM   #4
3757chevy
3757chevy's Avatar
Got the lower brackets painted , still need to install them and the uppers . I've replaced the power steering pump and hoses last week, replacing steering gear box this week. And working on a different shifter .
Old 07-05-2018, 09:27 PM   #5
elf w/capital T
Cooo000oo000ooollll! Nice!
elf w/capital T is offline   Reply With Quote
Old 07-06-2018, 01:09 AM   #6
3757chevy
3757chevy's Avatar
Name:  31015-007 coupler.JPG
Size:  11.4 KBThanks, still working on steering gear, had to order another, and another, they tell me at tech service that that's the right part in the box but I have two cores that have a smaller shaft on the input . So I ordered a bigger steering coupler to get it put back together next week( I hope ).
Old 07-09-2018, 12:02 AM   #7
3757chevy
3757chevy's Avatar
Well the truck is back together. including my shifter . I had to get rid of the mustang shifter that had been given to me eleven years ago. Now I have Hurst Pro-matic 2 ratchet shifter built into the floor. Here's a link to my shifter box build. http://67-72chevytrucks.com/vboard/s...d.php?t=767127
Old 07-09-2018, 05:43 AM   #8
elf w/capital T
Haha too much fun I see! Those real wood peices on the dash? Neat!
Old 07-10-2018, 09:27 PM   #9
3757chevy
3757chevy's Avatar
Yep. Thanks , here is a link to a post of my dash http://67-72chevytrucks.com/vboard/s...3&postcount=91 before my windshield was replaced.
Old 08-11-2018, 10:23 PM   #10
3757chevy
3757chevy's Avatar
Two months of planning, other fixes (and life things) I hope to get back to installing my brackets soon.
Old 08-22-2018, 01:15 PM   #11
HO455
HO455's Avatar
Looking forward to seeing the end results!
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 08-23-2018, 04:48 PM   #12
3757chevy
3757chevy's Avatar
... Me too, I hope my next weekend I can get 'r ' done. My granddaughter goes back to school this week , maybe I can get something done next Monday.
Old 08-28-2018, 12:26 AM   #13
3757chevy
3757chevy's Avatar
Well it is Monday. I got the upper brackets installed.This is the rivets I needed to grind and drill out. And a view of the old brackets and shock angles.
Old 08-28-2018, 12:59 AM   #14
3757chevy
3757chevy's Avatar
My 1st mistake was to not get my own measurement for the mount to frame. It should have been 6" not 5-5/8".(blue arrow in the 1st pic and yellow in the 3rd) My 2nd mistake was to drill my shock mounting holes at 1" not 3/4" from the end (yellow arrow) which caused the head of the mounting bolt to get in the way of the shock . So I grabbed a 7/16" bumper bolt to mount the rear of the bracket to the frame.
Old 08-28-2018, 01:04 AM   #15
3757chevy
3757chevy's Avatar
Installed and man what a difference in the ride.
Old 09-03-2018, 11:48 AM   #16
HO455
HO455's Avatar
Good job! I really like that you removed the bed floor so you could get us good photos of your installation. A couple of questions if you would be so kind. How close does the shock body come to the axle housing? And you did use the stock lowers?
Thanks again.
Old 09-03-2018, 10:00 PM   #17
3757chevy
3757chevy's Avatar
Thanks. I have a 1/2" sheet of plywood (held down with a 5/16" nut and flat washer on stud in center of the bed ,see arrow) for my bed floor for now, so it's easy access. The lower shock body has a good 1/2" clearance to the axle . I have not changed my lower brackets yet. I'm thinking about using a 1" lowering block on the rear and I want to replace the u-bolts either way.
Old 09-17-2018, 03:40 PM   #18
3757chevy
3757chevy's Avatar
I got things cleaned up a bit, touched up my bed liner and put my plywood back in for now.
Old 11-07-2018, 12:08 AM   #19
3757chevy
3757chevy's Avatar
I took out the rest of the bed wood (not much left) and metal strips and tucked the plywood under the angle strips. It looks a little better that way.
Old 07-13-2019, 09:48 PM   #20
3757chevy
3757chevy's Avatar
I have got my wood cut, placement chosen and now the sanding . Kinda like snowball effect, I keep finding things to work on.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
