06-21-2018, 02:15 PM | #1 |
Difference between Wilwood and Factory 1 1/8" Master Cylinders
What is the difference between the factory 1 1/8" MC and the Wilwood unit? I'm planning my brake upgrades and would rather not use the Wilwood if I don't have to. I obviously plan to use an adjustable proportioning valve to fine tune the front/ rear bias, and will also use the disc/disc combination valve (probably the one from LMC).
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
06-21-2018, 07:59 PM | #2 |
Re: Difference between Wilwood and Factory 1 1/8" Master Cylinders
Good question. I do not know, hopefully the more learned will educate us.
06-22-2018, 09:15 AM | #3 |
The look is the big difference, and it is set up for the kit they sell. Meaning that it will work with out mods to the mc itself.
06-22-2018, 02:03 PM | #4 |
Not sure what you mean by that, but the factory mc does not require any "mods" per say either.
06-22-2018, 05:10 PM | #5 |
I have wildwood disc on the front, drums on the rear of my truck, that the previous owner installed, with the stock cast iron mc with 11in booster. no proportioning valve on the mc. it stops nice with stock mc no issues but now im looking to upgrade the mc was looking at wildwood or summit brand aluminum mc.
06-22-2018, 05:16 PM | #6 | |
06-25-2018, 06:20 PM | #7 |
Question: is this for the 77. Qoute:The look is the big difference, and it is set up for the kit they sell. Meaning that it will work with out mods to the mc itself. He means there MC works with there set up. but it you use a factory mc you may or may not have to a just it (may be in the rod)
quote: I have wildwood disc on the front, drums on the rear of my truck, that the previous owner installed, with the stock cast iron mc with 11in booster. no proportioning valve on the mc. it stops nice with stock mc no issues but now I'm looking to upgrade the mc was looking at wildwood or summit brand aluminum mc. If so why there no factory proportioning valve on the center frame down by the bottom of the rad by the frame steering gear.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 06-25-2018 at 06:32 PM. |
06-25-2018, 06:25 PM | #8 | |
Thread Tools | |
Display Modes | |
