08-06-2018, 01:33 AM | #1 |
Qustion about sealer coat
Can someone tell me what the purpose of the sealer coat over the high build primer is and what will happen if it's not done?
I don't know if it matters but the truck that we're painting has no rust or dents and will only have high build on the front bumper and the tailgate.It's also going to be repainted the same color. The paint we're using is Nason.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
08-06-2018, 02:43 AM | #2 |
Post Whore
Re: Qustion about sealer coat
I was going to use Nason ss but decided to go with sherwin Williams ss instead ....I asked the sw guy about sealer and he said it wasnt necessary on ss paint since I'm high building the whole truck....I'm just going on what he told me....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-06-2018 at 02:54 AM. |
08-06-2018, 10:30 AM | #3 |
I have used Nason Ful-Thane ss urethane on a number of projects (mostly tractors/equipment, some work trucks, and my daily driver Oldsmobile). Although it does say sealer is required, I have cheated and skipped that step many times without having any adhesion / durability issues.
However, some colors are more opaque and cover better than others. If everything you are painting has all been sprayed with the same color primer, it's usually not an issue. But when you are painting over a mixture of colors (like some panels with original paint and others with primer or spot-primed repairs), the underlying difference in color can sometimes show through several coats of paint. Spraying everything with a coat of sealer gives everything a uniform color and prevents that from happening. If I were painting a truck with just a couple panels (like your bumper & tailgate) in primer and wanted to skip the sealer, I would probably spray an extra coat of paint on those primered panels to minimize the chances of a color difference showing through. |
08-06-2018, 01:30 PM | #4 |
"Basics of Basics" Paint technology
By Brian Martin There are many different types (or more correctly, technologies) of products you can use in the restoration or repair of your vehicle. Some have a variety of uses while others are very limited with only a few of specific uses. Proper choice of products can help you get the job done faster and/or help with the longevity of the repair. Let’s start with some basic definitions. I couldn’t possibly know every paint manufactures terminology or product use. These are generalities and should be used as a guide only to then read the tech sheets of the products you have chosen for proper use. These tech sheets can be found at the jobber and are given away free. Or most manufactures have them on line, USE THEM. They are a wealth of information and can save you many headaches. You don’t need to read every word in the mind numbing text, they usually have a “product at a glance” or something like that will cut to the chase and give you what you need. Basic terminology’s; “Solvent” is a generic term and refers to any “reducer”, “thinner” that is used to reduce the viscosity (“thickness”) of a product to aid in spraying or applying. It could be acetone, lacquer thinner, urethane reducer, a special “basecoat” reducer, water, alcohol, etc. These solvents ARE NOT INTERCHANGEABLE; each product MUST be used with the specific solvent recommended by the manufacture. “Etch primer” an acid containing primer. “Primer” a product that can be applied to bare metal “Surfacer” (or “primer surfacer”) A primer that has “body” or solids and is used to fill imperfections and provide a film thickness to sand or block a surface to a smooth base for paint. “Sealer” a non-sanding product that is applied prior to painting. “Primer-sealer” A sealer that can be applied over bare metal and then top coated without sanding. “Flash time” the time you allow the solvents to evaporate out of the film you have applied. Basic technologies; “Single component” or RTS (Ready To Spray). This is a product that uses no additional components. Just pour it from the can into your gun and shoot. Examples are: Some plastic adhesion promoters and primers and even some top coats like vinyl colors. “1K” This is a product that uses no hardener, catalyst, activator, etc. It may have an added solvent, but no hardener or activating reducer. 1K products like RTS dry with the evaporation of solvents and are soluble, meaning that they are could be wiped off with a rag soaked with lacquer thinner. They could in THEORY be scraped off and put in a can with solvent and stirred back to a sprayable condition. Of course ALL RTS products are 1K. Examples: All lacquer products, some synthetic enamel products, and some acrylic enamel products. Because of the low VOC regulations the 1K product options are getting scarce, with most limited to “specialty products” like adhesion promoters. “2K” or “Two component” is any product that uses a hardener, activator, catalyst, etc. It may or may not use a third component in the form of a solvent. 2K products don’t “dry” like a 1K. The 2K product “cures” by molecules linking together to form a whole new compound. Most high quality 2Ks are insoluble after a full cure and will not soften when exposed to solvents like thinners or gas. Examples are urethane under coats and top coats. Epoxies, ISO free products that use a hardener, etc. Basic tip, ALL 2K products should be mixed as accurately as possible. As a rule 2K products need a minimum of 55 degrees to cure with an ideal minimum of 65 degrees. MIX THEM AS DESCRIBED BY THE MANUFACTURE. They have spent hundreds of thousands, possibly millions of dollars developing the product, they WANT it to work as BEST it can. Do as they say, don’t become a “Junior Chemist”. Types of products and their uses; Etch primers (some are 2K) “Wash” or “Vinyl wash” are for bare metal applications for the ultimate in adhesion and corrosion protection. They are very low in solids with next to zero filling qualities. Some are even semi transparent. They are usually not to be top coated with paint. You apply them to aid in adhesion and corrosion protection under other undercoats such as epoxy or urethane primers. Benefits: - Very thin, keeps down film build - Cost effective - Fast application - Non-sanding - Super high corrosion protection. Disadvantages: - Some have a very small re-coat window “Etch primer” (some are 2K) Typical “etch primers” have much more solids and body than “wash” primers. They are more forgiving than “wash” primers, one thing being a much longer re-coat window. They are basically used to aid in adhesion and corrosion protection as with “wash” primer. You would choose “typical” etch over “wash” if you have some paint or plastic filler as a substrate along with the bare metal. Some brands have a recommendation to apply top coats over it also. This could be very useful in a money saving or time saving is important. Benefits: - Easy to apply, smooth, easy to sand - Some can be applied over plastic filler (not that you need it over the plastic filler, but if you have some, it is nice to not have to go around it) - Some can be top coated, which can be a big time and money saver. - VERY cost effective Disadvantages: - Added product to buy and apply. IMPORTANT basic! If you have used ANY metal treatment or “conditioner” read tech sheets carefully for compatibility . The acid in the metal “treatment” or “conditioner” can attack the acid in etch primers and it can LOOSE adhesion from the metal! Urethane primer (2K) Urethane primer is the most common primer used in auto body and restoration by far. It has good solids and fills well. It is easy to sand and can provide you with a perfect body when blocked properly. Care should be taken when applying it as to not use too much. It can shrink when applied too heavy. It is the best all around primer for applying over plastic body filler and for surfacing your work. If used properly it provides the proper film thickness under top coats and is the perfect substrate for bs/ss and SS. Benefits: - Easy to apply, and sand. - Applies smooth. - Fills well with minimum of shrinkage Disadvantages: - Contains Isocyanates. - Should always use an etch primer under it. Epoxy primer (2K) Epoxy is a good corrosion fighter. It is has a very sticky resin and will provide good adhesion to MOST substrates. It typically has poor filling and sanding qualities (that sticky resin makes sanding difficult) . It is ideal for use as a “primer/sealer” on bare metal that requires no surfacing. Perfect for frames and components, radiator supports, items that are sandblasted and you only need to prime and paint. You use it as a non-sanding “primer/sealer” and then paint right over it. Benefits: - Good chip resistance (it isn’t as hard as a urethane) - Perfect for a “primer/sealer” over bare metal. - Etch primers can skipped because of its excellent adhesion and corrosion properties. (although for maximum corrosion protection apply a wash etch under the epoxy) - Provides good base under plastic body fillers (skip the etch if you plan on using plastic filler over epoxy) - Epoxy has no isocyanates . Disadvantages: - Poor sanding qualities - Poor filling Polyester primer (2K) Polyester is a very specialized primer used in very small amount in most shops across the country. But when it is needed, it does a job like no other. Polyester has a huge solids content and will fill 80 grit scratches in one coat or 36 grit in two or three! Urethane for instance provides about ½ or ¾ mils per coat while polyester can give you as much as 4 to 6! Because of it’s high solids, it shrinks very little. It is basically like spraying polyester putty. Look for a manufacture that has a recommendation to apply etch primer under it. I see NO reason to use polyester on a straight panel. It is for use only when you need some serious filling and surfacing. Benefits: - VERY high filling - Low cost Disadvantages: - Very high texture - Harder to sand than a urethane - Possible need to purchase a large gun to shoot it. “ISO FREE” (2K) “ISO FREE” is a urethane type primer but without the harmful isocyanates that a urethane contains. The problem is ALL refinish products should be used with the same care and concern for your health and others. ISO FREE is like “low tar” cigarettes, don’t kid your self, it is still VARY harmful. Benefits: - Isocyanate free - Smooth, easy sanding - Good filling Disadvantages: - You need an etch over bare metal before it. Basic tips… Etch primers can be skipped on spots of bare metal smaller than a dime or so when using all primers listed. Most “quality” 2K primers need NO sealer before top coating with bc/cc or SS when applied properly. Sealers All RTS or 1K sealers should be reserved to VERY low end jobs to save money. They do NOT offer the benefits of a 2k, PERIOD. Reasons to use a sealer: - Makes up for “some” poor preparation - Provides a uniform color for better coverage when you apply paint. - Helps with providing a uniform substrate for paint. - Helps provide a better substrate when painting over a 1K primer. - Can Help with “covering” poor prior repairs Under collision repair conditions a shop may use sealers on every job as an “insurance” protection against problems. In a restoration environment where complete panels are primed with a 2K there really is no need to use them. If you have chosen to use a sealer there now are a few more choices to make. First, you need to decide what kind of sealer to use. As I mentioned in the beginning, RTS or 1k could be used to save money. Why put a 1K sealer over your 2K primer (I hope you are using a 2K primer) then apply a 2K top coat? It is like the old saying, “It’s only as strong as it’s weakest link”. If you use a 1K sealer in this fashion it is like replacing a link in your tow chain with a nylon tie! With 2K there are a few options, epoxy and urethane being the most popular. I don’t feel that there is a huge difference in the two as far as how they apply or work. Epoxy is more forgiving with sensitive substrates. It really comes down to what you feel more comfortable with. The epoxy has no isos so that would be one reason to choose it. Now that you have decided what sealer to use you have to decide on what application. Most sealers give you the option of a “wet on wet” (or very close to it) or a full “barrier coat” application. The difference being with “wet on wet” the sealer is applied and then allowed a short flash time before the basecoat or SS is applied. A “barrier coat” is where the sealer is applied, then allowed to cure or at the very least to totally flash. This allows the sealer to become a barrier so the solvents from the color coat can’t penetrate it and attack the substrate. The barrier coat procedure allows for he sealer to do MUCH more of what you choose to use a sealer for in the first place. The choice is made taking into account a few factors. How sensitive is the substrate? Or, how aggressive are the solvents in the color coat that you are applying? If it is very hot weather and you are using a slow solvent in the color coat to help it lay out, you may choose to use a sealer because you know that the substrate is sensitive and the slow solvent will attack it.
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-06-2018, 01:33 PM | #5 |
I personally don't use it on any restoration or hot rod work. I use a urethane or epoxy primer in the proper color and then paint right over that.
"Tintable" urethane primers are the only way to go in my opinion prior to paint. Brian
08-06-2018, 02:30 PM | #6 |
Joe Novice here,
what do you use to tint your urethane primer. Great info here by the way. Danny
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
08-06-2018, 03:03 PM | #7 | |
On that note, every manufacturer has a "Tech line" where you can call and get info. You don't need to be a pro or a shop or an account or something to do it, give them a call it's a world of information right there at your finger tips. I say this because every product is different, and some, those guidelines they make are VERY important. Brian
08-06-2018, 04:27 PM | #8 |
There are some colored primers that you literally have a formula to mix the color you need.
Brian
08-06-2018, 07:22 PM | #9 |
Thank you guys for all the help.
08-06-2018, 11:56 PM | #10 |
Martin i have a primer sealer question. My cab and box have mish mash of different primers on them, most put on by previous owners, some gray some tan some black some i know is rattle can because i did that just to get the metal covered after repair work. I have some 2k epoxy primer and some 2k urethane primer, surfacer. Whats your thoughts on my next step? I know i need to make it al one color before 2k base coat clear coat, but not sure on next step. I did a couple parts with each, epoxy lays out real nice mixing it according to tech sheet, the urethane not so much itneeds more pressure and or more thinner than tech sheet calls for. Talk me down off the ledge before i screw it up totally. Thanks
08-07-2018, 12:28 AM | #11 |
I would stick with the epoxy. But my big issue, BIG issue is all the different stuff there, what quality is it? What are your expectations? If you don't know what is there it may be best to remove it. But that could be stepping it up much more than you planned, so leaving it would be taking a little chance, sealing it all under epoxy would be the "bestest" way to do it.
But removing it of course would be the best way. Brian
08-07-2018, 12:43 AM | #12 |
thanks Martin, it may be awhile between epoxy and base coat, I assume it will need to be scuffed? correct? looking for a 20 footer, that i could drive most anywhere
08-07-2018, 10:05 AM | #13 |
YES what ever you put on there you need to sand it after that "recoat window" which is typically only a few hours. Some will be a number of days, but realistically, it needs a scuff anyway to knock down any dirt specs or stuff like that.
I am with you on the 20 footer, what is funny is most every single non car person thinks my Rambler which is more of a 40 footer is "restored." Drive it with a smile on your face! Brian
Thread Tools | |
Display Modes | |
