Old 08-16-2018, 09:33 PM   #1
ptrckdillard
Wheel and Tire Combo, Advice
Hello all,
I recently ordered and received my US Mags 18x9.5 with Nitto 275/40R18 rear and 18x8 with Nitto 245/40R18 front. Truck has a 3/5 drop on it. First let me say I have not seen the wheels and tires mounted in person, they put the wheels and tires on it at the shop and sent me these pics. Hopefully it looks better in person but I am not happy with the way they look as of now. They look way too small!!
My options I'm considering,
1) 60 series tire in rear and 50 series in front...might still be unhappy
2) keep current tires and lower truck further....I really don't want it much lower
3) 20" rims with same tire sizes, it previously had 20"s with 245/35/20 all around and filled the wheel wells much better.....loss on selling new ones and buying new ones
No matter what I choose, I'm taking a hit in the wallet, these are brand new but look just a tad small. I would really love to see pics of someone who has a similar set up with 18"s and 60 series tire on rear and 50 on front if anybody has one.
Thanks for your input
ptrckdillard is offline   Reply With Quote
Old 08-16-2018, 10:14 PM   #2
Bird dog
Re: Wheel and Tire Combo, Advice
40 series tires on 18" are a bit small for these truck, in my opinion. I have the 20" (9.5" rear and 8" front) Ramblers on my build with 40 series tires (245 &275). My truck has a 4/6 drop and the top of the rubber is at the fender. The wheels are off my truck so we can bleed the brakes and I dont have any pics of the wheels and bed on the truck. Heres the best pic I have so far....
Bird dog is offline   Reply With Quote
Old 08-16-2018, 10:28 PM   #3
ptrckdillard
That's a great stance, just what I'm going for, I figured the only way to get away without lowering is to go with 20's again. Thanks for posting.
Old 08-16-2018, 10:38 PM   #4
SC1969c10
40 series are way too thin for an 18 on these trucks. I ran 18” billet specialties with 40 series tires on my 71 nova 20 years ago and it was slammed tonthe ground.
You figure my 15’s have a 10.5 wide by 31 tall tire on them and im dropped 2 in the front/ stock height out back.
With 275 width you would want 55-60 series for a stock height profile?
And while im thinking my ram has 275/55r20’s on it that spec out at 33’s
You really need to check the specs on the companys website as they all vary. But like you were getting at, one series thinner on the front.
SC1969c10 is offline   Reply With Quote
Old 08-16-2018, 10:43 PM   #5
ptrckdillard
With 275 width you would want 60 series for a stock height profile, so maybe down to a 55 since your lowered?
Thank you,
trying to figure out which bullet I want to take
Old 08-17-2018, 12:14 AM   #6
popik
Your timing is spot on. I just finished going through the same agony as you and was set on 18" rims no matter what. I ended up with 18x9.5 rear running a 265/60 and 18x8 front running 255/55 Nitto tires. They fill the wheels wells perfect. The photo is with a 3" rear drop that i just changed to 5" and the front is a guess at 3-4". Im not looking for a set of drop spindles for the front as theres room to go down a bit more.
http://67-72chevytrucks.com/vboard/s...d.php?t=571262
this thread has some great examples of what 18" tires look like when done right
popik is offline   Reply With Quote
Old 08-17-2018, 02:00 AM   #7
ptrckdillard
Thank you,
That's probably the route I'm going for now anyway, will be least expensive. Truck looks great
Old 08-17-2018, 09:06 AM   #8
slowcpe
slowcpe's Avatar
I've been in the same boat. Problem is there are not a whole lot of optimal options for trucks with 18s. I'm running 18x8 front and 9.5 rear Ridlers. Currently I have 235/50/18 on the front and 255/55/18 on the back. I've pretty much decided on 245/45/18 front and 295/45/18 in the back. There's a decent possibility I'm going to have to run a 1/4"-1/2" spacer to make the back work.
Truck has 2.5" drop spindles and 1 coil cut out of the front and a 4" drop spring in the rear.
This truck is just a cheap beater so I'm trying not to spend any more money than I have to and already had these wheels. 20s have a lot more tire options and that's what I'm going with on my '67 project.
Truck as it sits now.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 08-17-2018, 09:25 AM   #9
ptrckdillard
Thank you, truck looks good. My main concern with going to a 55 or 60 series is that all the side markers are shaved and there is not going to be trim on the truck. My personal opinion on the wheel and tire set up is it needs to have a lower profile tire more of a pro touring style look due to the trim and markers being shaved. Pretty sure only way to do that is go bigger and lower. After seeing yours and the step side above, I think I'll be happy with a higher profile.
I researched a ton and looked at close to a hundred trucks in person and even more online trying to get this right the first time. Only thing better than education is experience...right!!
thank you so much for your input
Old 08-17-2018, 09:42 AM   #10
beaterku
beaterku's Avatar
I currently have 18x9's all around with 265/50/18 tires. I am now on a Ridetech Streetgrip kit and may have to go to a shorter tire once the truck is done. They say it is roughly a 4/6 drop. I am almost tucking in the front and it hasn't settled yet.
beaterku is offline   Reply With Quote
Old 08-17-2018, 09:48 AM   #11
slowcpe
slowcpe's Avatar
Here's a truck on the board with a similar setup to what I'm wanting. 255/45/18 front and 294/45/18 in the back.
http://67-72chevytrucks.com/vboard/s...9&postcount=53
Ryan
Old 08-17-2018, 12:38 PM   #12
ptrckdillard
Looks really good, I guess I don't hate the taller sidewall. I appreciate it.
