12-05-2018, 12:09 AM | #1 |
Are OEM-type gas tank straps available?
I'm not very happy with the straps that came with my new tank and would much rather have OEM-type or at the very least some detailed pictures and measurements so I can have some built. Mine were completely shot, one was rusted clear thru, and I never did save or even take pictures of them
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
12-05-2018, 10:08 PM | #2 |
Re: Are OEM-type gas tank straps available?
I rebuilt mine using the original ends and hardware but with new metal straps. If you can find a used set maybe you can do the same thing.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
12-05-2018, 11:33 PM | #3 |
Yeah-that just might work. Good idea!
12-06-2018, 09:45 AM | #4 |
The originals used rivets but I just used bolts and metal the same thickness. For a padding between the tank and strap I used rubber roofing material.
Paul
12-06-2018, 12:10 PM | #5 |
Post Whore
This isn't the best photo but it may help.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-09-2018, 05:38 AM | #6 |
Grab 1 extra set of j-bolts that like came with the new straps and then hook one side in frame then attach one side of straps to them form the straps to tank bottom and up other side and then insert j-bolts in the other side to connect to opposite side of frame. Some use standard bolts do this but I've found a extra pair of j-bolts work best. OEM straps aren't made.
Paul Sr @ GMCPauls |
12-11-2018, 06:19 PM | #7 |
Equal opportunity joke ofender
I may have an extra set of straps if you end up needing some originals. I will double check if you do.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-13-2018, 08:38 AM | #8 |
Pritch
here is what i have. I don't have any j bolts or stamped plates, just the straps Richard .
