03-25-2019, 08:17 PM | #1 |
Outer Window Sweeps
Talking about the rubber flaps that slide in a slot inside the door window opening to seal and wipe your side windows and prevent rattling.
I've replaced these on a couple of AD trucks, always with extreme difficulty - or in the case of my current panel truck I wasn't able to get them in at all. I thought, no way were factory assemblymen going through this much hassle to install these! Now I find that many vendors are selling generic extruded rubber seals that bear no resemblance to originals. What many are selling has a T-shaped base. When I chiseled my old rubbers out, they had a Y-shaped base. I did some research and found that Classic Parts sells the original-style y-shaped seal (part #03-711 Outer Rubber Window Seals). And at $5.95 it's not like they're expensive. I bought some and they slip right in effortlessly. If you're replacing your window sweeps do yourself a favor and get this type. Below is a photo profile of the original style, Classic Parts style, and the generic style that most places sell. Notice how huge the t-style base is; no way will it fit in the door slot without extreme measures!
1951 Chevy Panel Truck |
03-25-2019, 10:03 PM | #2 |
Re: Outer Window Sweeps
I bought a set from Classic Parts for my 49 about 6 yrs ago and I second that they fit & work.
03-25-2019, 10:34 PM | #3 |
Thanks, that is one to put in the notes for later. I wish I could find bulk lengths of both the inner and outer though.
03-26-2019, 01:06 AM | #4 |
Thank you, just placed my order.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
03-26-2019, 09:03 AM | #5 |
Too late for me.
I sanded the T shaped ones down to the Y shape. Not fun. The rubber cowl vent and side vents are too thick also and require modification.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
03-26-2019, 09:07 AM | #6 |
Mine looked like the ones on the right. Real pain to put in and I needed to trim a little. Are they wider?
1950 Build |
03-26-2019, 11:23 PM | #7 | |
1951 Chevy Panel Truck Last edited by MiraclePieCo; 03-26-2019 at 11:30 PM. |
04-12-2019, 09:58 AM | #8 | |
AD Addict
Who did you get yours from? I used Classic Parts and no issues. Of course, no original to compare to so there was that! I may be fat, dumb, and happy. And wrong! |
04-12-2019, 11:28 AM | #9 |
I just received mine that I ordered the day that thread was posted about these. They had an issue with the other part I ordered (the pair of little pieces that go over the ends top of and bottom of the center inner windshield moulding) so I just got them. This is from Classic Parts of America and the part number is 03-711 and only $5.95 for the pair.
You probably already got them but I thought I would let you know. The rubber I am comparing it with is an original I got out of one of my doors. it's not flawless, but damn close as long as it's not to big sticking out where it hits the glass that is. Brian
