Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-28-2019, 10:07 AM   #1
CG
BlahBlahBlah
Keeping things aligned
Im assuming its ok to talk about vehicles here besides our trucks.
I have a 65 Corvair convertible Im going to be totally stripping down for body work and paint. Corvair is a unibody car and Im going to build a roll around cart for it since all suspension and drive train will be taken off.
Right now the hood, trunk, and doors line up pretty darn good. I want to make sure they go back together the same way. Ive read drilling the door hinges for an alignment pin is the way to go. Do I need to weld braces in the door openings? Any trick to aligning the hood and trunk when finished?
MONROE SPRING SWAP MEET
MAY 16-17 2020
CG is online now   Reply With Quote
Old 11-28-2019, 01:15 PM   #2
nsb29
nsb29's Avatar
Re: Keeping things aligned
I drill holes when ever I can don’t know about Corvair hoods or trunks not sure witch is witch, is the hood trunk or is the trunk the hood lol. No you don’t need to brace your openings
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 11-28-2019, 01:36 PM   #3
mongocanfly
Post Whore
Welding in bracing will depend heavily on if your having to replace floorboards/rockers and such...
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 11-28-2019, 08:40 PM   #4
nsb29
nsb29's Avatar
That’s right if you cut into the floor or rockers You need to brace it I didn’t pay attention I thought I read they’re ok thanks mongo
Old 11-28-2019, 10:31 PM   #5
mongocanfly
Post Whore
I'm not sure hes gonna have to replace any of it...but I just throwed that out there just in case
Mongo...aka Greg
Old 11-30-2019, 01:09 PM   #6
CG
BlahBlahBlah
No rust thankfully.
MAY 16-17 2020
Old 12-01-2019, 09:43 PM   #7
theastronaut
theastronaut's Avatar
No need to brace a unibody car if you're not cutting it up.
theastronaut is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
