Old 12-18-2019, 01:21 PM   #1
KyFarm
Active Member
KyFarm's Avatar
carb sizing
I am about to pull the plug on a Chevy HT383.
Some literature from Chevy says to go with 770 cfm carb
Other lit from Chevy say to go with 670cfm
Called Holley and they said Chevy always oversizes their recommendations for crate motors and they don't know why.
Holley ran math and said a 570 is what is perfect for the HT383.
Any thoughts on what size to go with?
Motor will never see the top of the rpm band, 69 K10, just want to drive it around the country roads around my farm.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 12-18-2019, 01:44 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: carb sizing
I'd go with what Holley recommends...a 600cfm should be fine
Although I've ran everything from a 390 to a 750 on a 350sb
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 12-18-2019, 02:28 PM   #3
The Rocknrod
MCPO USN Ret.
The Rocknrod's Avatar
Re: carb sizing
Street Carb CFM : 470.99
Racing Carb CFM : 609.52
(using 5,000 RPM)
https://www.summitracing.com/newsand...cfm-calculator
Old 12-18-2019, 04:55 PM   #4
truckster
truckster's Avatar
Re: carb sizing
I'd go with a Quadrajet. It will give you the best performance for anything from a little 283 to a great big 455, and probably beyond that.
If I didn't build it or fix it, it's probably not mine.
truckster is online now   Reply With Quote
Old 12-19-2019, 02:26 PM   #5
PGSigns
PGSigns's Avatar
Re: carb sizing
I have a Holley 670 street avenger on my L31 crate engine with a comp cam and a super victor. Really runs well.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-19-2019, 08:08 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: carb sizing
I have always ran 3310's (750 cfm) on my worked over street strip 350 engines. For funs I built an 1850 (600 cfm) with center hung bowls and a 4 corner idle circuit for my current street/strip 350 in my 1972 GMC. I gotta say the 600 cfm is a lot more fun on the street... When I hit the drag strip I'll take the 750 with me and switch if I need to.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 12-19-2019, 08:16 PM   #7
cadillac_al
Re: carb sizing
Back when I used to read every hot rod magazine out there, they would do engine builds and calculate the cfm requirements. They would come up with those same low (theoretical) cfm numbers and then try a 600 carb for the first dyno runs. Then they would slap on the trusty Holly 750 and the dyno numbers would go up. I read the same story many times. In the end they seemed puzzled and theorized that "this particular engine just works better with the 750 carb". I'd say buy a 750 and forget it.
Then again we don't build engines just for the dyno. I still think a 600 carb is too small for a high performance 383. The 600 could be nice and peppy in every day driving and may be the hot ticket in a street truck. I guess it is a tough call.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 12-20-2019, 08:08 PM   #8
Tom
driving is in my blood
Tom's Avatar
Re: carb sizing
The engine will use 600cfm. A 600cfm carb running 600cfm has to be creating some vaccum, which reduces power. A 750 is breathing easier at 600cfm hence the power increase.
OP- For a stock ht383, that won't be upper rpm, a 600cfm carb is plenty. So go with the 670 out of your two choices.
Old 12-26-2019, 08:37 PM   #9
KyFarm
Active Member
KyFarm's Avatar
Re: carb sizing
thanks for all the info
Old 12-30-2019, 12:05 PM   #10
vince1
Re: carb sizing
'Throttle shaft bushing repair kit' are the words you want to enter into Amazon if your throttle bores are worn out. The kit comes with bushings and a reverse cut reamer.
I wish I had this kit before overhauling my Quadrajet, although it does seem to work OK as is.
vince1 is offline   Reply With Quote
Old 01-05-2020, 09:36 PM   #11
Myself
Re: carb sizing
We had a real healthy 350 with a Street Avenger 670.....great carb, good street manners to.
I have a mild built 305 that was my daily for 16 years. 570 Avenger on that one.
My next build will be a VERY healthy vortec headed 350...it will get a Street Avenger as well.
Myself is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
