Old 11-27-2020, 04:07 PM   #1
Thealien
Thealien's Avatar
Intake manifold Brake booster plug
I will be installing a hydratech hydroboost brake set up in my Blazer. Because of this I need to plug the hole where the brake booster got its vacuum. Trucks with factory hydroboost have the plug in that location. I do not want to put a bolt in a hose!
Does anyone have the GM part number for that plug?
It will look like this but it is solid instead of hollow.
Old 11-27-2020, 05:03 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Intake manifold Brake booster plug
Years ago I tried to find the part number for that plug and never did find one for it. The part its self doesn't have a number cast into it either. But if you send me your address I'll send you this one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-27-2020, 06:35 PM   #3
Thealien
Thealien's Avatar
Information sent. Thank you so much!
Old 11-27-2020, 07:42 PM   #4
geezer#99
geezer#99's Avatar
Can’t you find and use a vacuum cap on the original fitting?
geezer#99 is online now   Reply With Quote
Old 11-27-2020, 09:47 PM   #5
Thealien
Thealien's Avatar
You could but why when they make the correct part?
Old 12-01-2020, 06:02 PM   #6
beaterku
beaterku's Avatar
AC Delco #12559760. This is the part number for the nipple.
Edit: I see that you are looking for the part number for the plug. Looks like ICT billet make a billet plug that you could use. I have a couple around somewhere, but I cleaned and not I can't find anything lol
My 72 SWB build
My YouTube channel
beaterku is offline   Reply With Quote
Old 12-02-2020, 10:11 PM   #7
StingRay
StingRay's Avatar
I have a bag full of those plugs.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-02-2020, 11:02 PM   #8
gmc684x4
Do you have a part number ?
I have been looking as well
I can find lots of vacuum booster nipples no vacuum plug numbers
gmc684x4 is offline   Reply With Quote
Old 12-03-2020, 06:59 AM   #9
Thealien
Thealien's Avatar
You wouldn't happen to have a part number for that bag full of them?
Old 12-03-2020, 10:44 PM   #10
ls1nova71
ls1nova71's Avatar
Did you not get the one I sent you?
Old 12-04-2020, 04:06 AM   #11
Thealien
Thealien's Avatar
No sir. But the part number may help others?
Old 12-04-2020, 09:26 AM   #12
ls1nova71
ls1nova71's Avatar
I sent it out Monday morning. I'll have to find the receipt from the PO to see what happened to it.
Old 12-06-2020, 11:38 AM   #13
solidaxel
solidaxel's Avatar
The luck I am having finding this plug is not working!
I had a vacuum cap on that port but the engine hiccupped and it took a long time to find the problem......... it blew the cap off, so I need a bag of the RIGHT plugs as I have 3 engines not using this port
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
