Old 01-17-2021, 10:56 AM   #1
57FleetsideC4
57 Fleetside C4 build
Hi All, I figured I should start a build thread since been a member for a while. I picked up a 57 big back window custom cab with 58/59 fleetside bed that has been converted to C4 suspension front and rear. This was a started project by the previous owner. I have done a half dozen body off restos on 67-73 olds 442's and this will be my first truck. I know the truck looks pretty good in the pictures but the front floors, cab mounts and cab step areas needed work. I have been working on it the last 5 months and will get the thread up to date. Thanks Steve
57FleetsideC4 is offline   Reply With Quote
Old 01-17-2021, 11:06 AM   #2
57FleetsideC4
Re: 57 Fleetside C4 build
This was the teardown just after getting it. I came with a lot of parts including a LT1/4l60E that I am not using. There is at least 5 different trucks that parts were collected from. Steve
Old 01-17-2021, 11:20 AM   #3
57FleetsideC4
After looking everything over and coming up with a plan I got started on the cab first. Someone had install step plates over the original, mudded over holes in the hinge and lock pillars and installed some pretty ugly floor patches. I will be installing, front floor patch panels, front cab mounts, cab steps, lower "A" pillars, Lower "B" pillars, right lower plenum and inner and outer cab corners. Plus made some patches for pieces not reproduced. Steve
Old 01-17-2021, 11:29 AM   #4
57FleetsideC4
Starting to patch up the cab in the left plenum, A and B pillar and step area. My welding is not the greatest but will not fall apart. Steve
Old 01-17-2021, 11:44 AM   #5
57FleetsideC4
While I was patching the cab up I was thinking about what powertrain I was going to use. I settled on a 6.0 LS with a 4L80E trans from Just Chevy Trucks in Maine. This is one of there Hypermax builds in which they install rebuilt 5.3 heads on a 6.0 for more compression, new roller cam, lifters, cam bearings, oil pump and timing chains. They dyno the engine, tune a pcm to your specs with a stand alone wire harness. My engine made 472 h.p. at the crank which should move this truck good. They also supplied the 4L80E completely rebuilt. They did the engine, trans, harness and all associated parts like pcm, fuel pedal (mine will be DBW)and gaskets all for $4500 delivered to my door which I think is a good deal. Steve
Old 01-17-2021, 02:46 PM   #6
57FleetsideC4
After getting the engine and trans settled went back on the cab. First was finalizing the B pillar and inner cab corner I test fit the step which did not go well. The step rocker was at least a 1/2" below the cab corner. Should have known when the inner cab corner was to high and cut it down. someone had done cab corners and put them in to high on the body. After replace the out cab corners was able to get it aligned much better. The first test fit of the right door went well an gaps not too bad. Steve
Old 01-17-2021, 03:44 PM   #7
57FleetsideC4
Some more pics. This of the left side same area plus the fuel filler hole. Steve
Old 01-17-2021, 04:01 PM   #8
57FleetsideC4
After the cab work needed to test fit the LS engine and trans just to Make sure it fits. It was tight but fits great. I used the Dirty Dingo slider mounts which raises the engine 1/4" over other mounts and I needed it to clear the rack. these mounts allow the engine to be slid where you need it. Steve
Old 01-19-2021, 05:43 PM   #9
5winElJefe
Looks like a great start to a project. Killer deal on the engine/trans setup. 472hp ought to move her along pretty mightily!
When it comes to cars, only two varieties of people are possible - cowards and fools. -Russell Baker
1975 Toyota FJ40
1953 GMC 5 window
1963 Falcon Convertible
5winElJefe is offline   Reply With Quote
Old 01-20-2021, 11:53 AM   #10
washington blue
This is going to be a fun truck, good job. Have you set your radiator and electric fan in place? I had to alter my firewall a little and move the engine back about 2" so I have lots of fan and shroud room. Some radiators are thicker than others and some fans - shrouds are thicker/thinner too.
washington blue is offline   Reply With Quote
Old 01-20-2021, 07:35 PM   #11
57FleetsideC4
Thank You. I did not think I could go wrong for the price. A good friend used the same company for his 49 pickup only he used a 5.3/4L60E combo and runs great. Steve
Old 01-20-2021, 07:39 PM   #12
57FleetsideC4
I have 7" from the face of the core support where the radiator mounts to the front of the water pump pulley. The radiator fan combo I am looking at is 6.75" at its thickest point. It has 2 offset fans and hope where the middle of the assembly is shorter than the thickest part to make more room where the water pump is. Steve
Old 01-21-2021, 11:27 AM   #13
Kevin_C
looking good. we are running fairly similar setups. Im hoping to tack in my motor mounts and test fit the radiator this week. Do you plan on running either front or rear sway bars?
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 01-21-2021, 12:03 PM   #14
57FleetsideC4
I wasn't planning on running sway bars. The guy I bought this from does a lot of these and he wasn't running sway bars on his builds. I don't know if you could get the stock corvette bars in there. Steve
Old 01-21-2021, 04:05 PM   #15
slammed57
slammed57's Avatar
nice work!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 01-21-2021, 04:44 PM   #16
57FleetsideC4
Originally Posted by slammed57 View Post
nice work!
Thank You. This one is really testing my skill set! Steve
Old 01-21-2021, 04:54 PM   #17
57FleetsideC4
Test fit a second set of headers. I tried the shorty set from speed engineering and the #5 tube was too far in the way of the steering shaft. I bought a set of long tube headers from speed engineering and they fit perfect other than having to trim the right ear on the 4L80E trans and flexplate cover.
Another problem I am trying to figure out is the aftermarket front fender alignment at where the fender meet the cowl near the windshield. It fits good at the back but is high at the front. Any help would be appreciated. Thanks Steve
Old 01-21-2021, 05:01 PM   #18
slammed57
slammed57's Avatar
I had the very same issue with the aftermarket fenders. It took some time to cut and weld to fix it to get it right... after all that work I still ended up going with originals just because the originals were a thicker gauge metal. but you can fix it... just time and patience
My 57 current build
Old 01-22-2021, 12:17 PM   #19
57tailgater
While it seems there's some definite fitment issues with the reproduction schtuff, I recently came across a good video showing how to align TF's panels. Maybe this will help some.
https://youtu.be/RgUwd9PdWiA
57tailgater is online now   Reply With Quote
Old 01-22-2021, 01:33 PM   #20
_Ogre
master of none
_Ogre's Avatar
imo you got a smoking deal on your motor/trans setup, the more people getting into that type of tuning/conversion the better the pricing gets. i spent that much just on my ramjet 350
nice headers, i wish i had gone thru the trouble to find nice long tubes vs my block huggers
have you figured out your shift linkage yet? the left lever gives you more room but your going the wrong way. i can tell you what i did
shop air compressor timer
Old 01-22-2021, 01:39 PM   #21
57FleetsideC4
Thank You.
Old 01-22-2021, 04:37 PM   #22
57FleetsideC4
I figured that out. I am putting in a ididit column when the time comes. I never saw a column with the shift arm on the left side like that. It came out of a 89 chevy van I think. thanks for pointing that out. Steve
Old 01-22-2021, 07:24 PM   #23
slammed57
slammed57's Avatar
heres a video from Jodaddy that really helps with the fenders
https://www.youtube.com/watch?v=6vwg_loea5w
My 57 current build
Old 01-22-2021, 10:24 PM   #24
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
VERY nice build! Great work.
87Lowrider is offline   Reply With Quote
Old 01-23-2021, 05:53 PM   #25
57FleetsideC4
I had watched that video before. Very informative. Thank You.
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
