Old 09-02-2021, 07:08 PM   #1
easyrider
easyrider's Avatar
installing the chrome divider strip on cab
I have got to drill the holes for the tabs that will hold the chrome divider strip between the top color and the body color. I need a little help as to what size holes and how far apart to drill them and how many I'll need.
And, do I drill them after body work and before paint?
Someone had a diagram that answered all my questions (well, almost all), but I can't find it.
And, while I'm on the subject of drilling holes for chrome. I have complete side chrome that has to be mounted and I'm a little leary of getting those holes in the right place and centered.
As, always, any and all advice and instructions is greatly appreciated....Thanks in advance!
easyrider is offline   Reply With Quote
Old 09-02-2021, 07:18 PM   #2
the67Beast
Junior Member
the67Beast's Avatar
Re: installing the chrome divider strip on cab
Maybe the cab back molding changed, but mine (1967) has little standoffs instead of holes drilled. Not certain how the standoffs are connected to my cab, but there is a little plastic clip that snaps and slides over the standoff, then the actual molding snaps over the clips. I can try and get a photo tomorrow (at work tonight). Maybe someone else will chime in in a little while.
the67Beast is offline   Reply With Quote
Old 09-02-2021, 07:30 PM   #3
easyrider
easyrider's Avatar
I saw the little stand off tabs on some ones photo but I don't know where to get them or what they are called. those are the ones I would like to use. Thanks!
Old 09-02-2021, 08:24 PM   #4
Grumpy old man
Grumpy old man's Avatar
This thread should help . the clips are AU-VE-CO 11288
Buy 100 and sell the rest
https://www.fastener.zone/products/a...530-gm-4492962
Install thread
http://67-72chevytrucks.com/vboard/s...d.php?t=767786
Stud rivits https://www.txdashcovers.com/blripintywcl.html
Blind Rivet-Pin Type W/Trim clip stud
Replaces Weld-on stud for attaching stud style moulding clips to panels
Rivet 3/32" (m2.4) Upper Flange 0.197 (5.0) Max Grip range 0.098 (2.5)
Qty-25 Rivets for 1-Low Price
Aluminum Rivet and Mandrel
Grumpy old man is offline   Reply With Quote
Old 09-02-2021, 08:30 PM   #5
Steeveedee
Steeveedee's Avatar
^ That right there is a ton easier than welding those mounts back on, like the factory did!
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 09-02-2021, 08:32 PM   #6
Grumpy old man
pix
Old 09-02-2021, 11:47 PM   #7
Grumpy old man
Best deal on rivits and clips .
https://www.clipsandfasteners.com/3-...t-p/a20987.htm
https://www.clipsandfasteners.com/se...=11288&Submit=
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
