The Older Generation
![]() ![]() Join Date: Aug 2006
LockDoc's "Low Budget", "Low Maintenance" Project Thread
I have been working on cleaning the shop for the last 2 months but I have had some delays. I finally got it cleaned out enough to get this truck inside so I will go ahead and start a thread on it.. This project is for all of the guys and gals that don't need a show truck but want something different to drive. Hence the "Low Budget". Low Maintenance" part. I am starting a new project. It won't be a quick assembly and it certainly won't be a show truck. It will be a new adventure for me. I'm usually pretty much by the book, but this build will be completely the opposite. I have this pretty nice '72 GMC 3/4 ton leaf spring frame and '71 cab & bed that I need to use. I didn't want to post anything until I knew I was going to have time to actually work on it over the winter but I started working on it outside last fall. I will still only be posting what I have done bit by bit instead of all at once. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-14-2022 at 11:53 PM. |
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I Pulled the bed off of the truck a day or two ago and I removed the cab today. They were just sitting loose on there so they didn't have to sit on the ground. I removed the Small Block frame brackets, and the bell housing cross member is next. LockDoc
![]() Join Date: Dec 2009
I Am in for the Build
![]() Are those Vintage Green bean cans on the exhaust?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
BlahBlahBlah
![]() Join Date: Feb 2002
Oh boy, I know where this is going and look forward to your updates.
![]() Join Date: Jun 2002
Man, it would be a great time to go ahead and rebuild the front suspension. And maybe cleanup and paint the frame.
Good luck, Rg
Roger '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice project Leon. I know you have been waiting for this for a while.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#7 | |||
![]() Cheater. Quote:
LockDoc
All about them Ks
![]() ![]() Join Date: Jun 2014
I like cheap and not as aesthetically pleasing to the eyes
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Got the bell housing cross member out and the new engine frame brackets installed. I need to remove the stock exhaust system and brackets next. LockDoc
Removed the exhaust system and worked on the rear axle a bit trying to figure out how I want to set it up. I think I can use the stock '72 leaf spring hangers on the front end and just make some rear shackle brackets to get the results I need.. LockDoc
![]() Join Date: Sep 2014
Love the pics of the big breaker bar and torch! Keep em coming!
![]() ![]() Join Date: Jul 2002
Very kool. In to see what ya do with this one.
Bill 1970 Chevy Custom/10 LWB Fleetside Member of Louisiana Classic Truck Club (LCTC) Board Vendors Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! |
#13 |
Leon, Job well done!!!
I see 72 big block mounts.....Is it getting a big block or a small block, using the "better" big block mounts? (I plan to do such on my 67). Jeff |
#14 |
#15 | |
#16 | |
The answer will be in one of my updates coming up... ![]() LockDoc
#17 | |
The Kraut comes in a smaller can. They don't think the consumer will notice... ![]() LockDoc
#18 |
Worked on replacing the front spindles today. It was a bolt in deal and worked out great. New assemblies were off of a '73 truck. Don't make fun of my Rube Goldberg jack setup... ![]() LockDoc
#19 |
Proprietor of "Dale's Corner "
![]() Join Date: Nov 2012
Dually?....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck |
#20 |
![]() I'm already going to have a little delay because I have some volunteer work to do at the local Historical Society building for the next couple of days. I need to put some display cases together for them. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-20-2022 at 07:31 PM. |
#21 |
Worked on cleaning up the frame a little and pressure washed it so I can spray it with Rust -Oleum satin black in a day or so. My heavy duty pressure washer is a gas powered unit and when I wash something like this frame it almost looks like you are sand blasting it. It still has a thin layer of rust but that is what Rust-Oleum paint is for, right? That makes it "Close Enough"....
#22 |
Leon, you can buy that POR-15 paint in spray cans. It’s a little pricey, but it’s some awesome stuff!!!
#23 | |
LockDoc
#24 |
I worked on the rear frame spring hangers. The original brackets were hard to cut on an angle so one spacer had to be a 1/16" thicker than the other. I finished them up and bolted them on. LockDoc
#25 |
Leon, you haven't answered my question yet...the suspense is killing me..dually?
Thread Tools | |
Display Modes | |
