Old 01-02-2004, 05:22 PM   #1
ScottH
ScottH's Avatar
How can u tell the difference between a 305 vs a 350?
Can anyone give me a way to tell by looking at an engine if it is a 305 vs a 350? I know I can run the numbers, but when an engine is in a car you can't always get to them. I'm looking at a mid 80's Camaro for the drive train, but I believe they used 305's in them during those years.
Any info is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 01-02-2004, 06:08 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
They look identical. Running the numbers is the only sure fire way of telling.
67Fleetsidedream is offline   Reply With Quote
Old 01-02-2004, 06:14 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
You should be able to see the engine size on the radiator support, it should be on a sticker there. If it's a Camaro with a 5-speed, it's a 305 most likely. with an auto, it's hard to tell.
jmanz69 is offline   Reply With Quote
Old 01-02-2004, 06:16 PM   #4
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
Camaro's with 5 speeds had 6 cyl. in them- had one. Autos had 305 v-8 and Z-28 Camaros only had the 350.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-02-2004, 06:28 PM   #5
neonlarry
neonlarry's Avatar
You could get v8 5 speed camaros, but they are all 305s. If its a carb engine, the RPO code for the 305 is either lg4, or l69. The l69 is the 305 ho with the dual snorkle air cleaner, the lg4 is just kind of plain looking, and has a normal air cleaner.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-02-2004, 06:32 PM   #6
woodrow59
OzarkHillbilly in Atlanta
My truck has a '85 305,,,,,,,look on the block below the #1 spark plug (passenger side, front plug). Mine has 305 cast into the block. Don't know if they did that to all of them but it's worth a look.
IMO,,,,,,I'd look for a different engine. Mine is a dog,,,,,it will barely pull this 3/4 ton longhorn. I've heard other people have promblems with these engines too.
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 01-02-2004, 07:04 PM   #7
1972C10
1972C10's Avatar
Yeah i know lots of people with factory 5 speed 305s ive got a motor that came out of an 84 t/a thats the ho .. and im workin on an 84 z that has the 305 with a 5 speed. pretty common.
1972C10 is offline   Reply With Quote
Old 01-02-2004, 07:13 PM   #8
mooneyes
mooneyes's Avatar
.i've got an 84 305 and it has 5.0 stamped on the back right above the bellhousing bolts behind the distibutor..pretty easy to see
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 01-02-2004, 07:14 PM   #9
jmanz69
jmanz69's Avatar
My buddy had a 84 camaro with a 305 and 5-speed. Was a decent car, not fast. Fun as hell to drive though. We beat the crap out of that car, and then he sold it to some high school kid who thought it was the coolest ever.
Old 01-02-2004, 07:15 PM   #10
mooneyes
mooneyes's Avatar
oops almost forgot most cars and trucks that had 305's usually had a smaller neck on the top radiator hose..the part on the radiator..if you ever go to buy a radiator or top hose and they ask if its 305 or 350 it does make a difference
78 caprice project
Old 01-02-2004, 07:31 PM   #11
junkyarddog1956
junkyarddog1956's Avatar
I the car still has the factory engine in it , you can tell by the VIN# , which is the eighth digit from the left . It can either be a # or a letter depending which engine it is ....... jyd
69 Chev C-10 ... painted and ready to reassemble ( for sale )
82 Custom Deluxe ( have parts to restore )
junkyarddog1956 is offline   Reply With Quote
Old 01-02-2004, 07:42 PM   #12
Chevelle454
Chevelle454's Avatar
The 305 is a good engine. It gets good milage, doesn't burn much oil, and lasts forever. But for performance, it is no good.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 01-02-2004, 11:42 PM   #13
ScottH
ScottH's Avatar
Thanks to all for all the great info. I've had several 305's and really haven't had much luck. Considering the availability of 350's I personally don't want to get another 305.
BTW the Camaro I believe has a 700R4 if that helps.
Thanks again.
Old 01-02-2004, 11:45 PM   #14
Randy70C-10
Randy70C-10's Avatar
A 305 is fairly easy to identify. They are usually attached to the end of an anchor chain. (sorry)
Randy70C-10 is offline   Reply With Quote
Old 01-02-2004, 11:47 PM   #15
Randy70C-10
BTW, Virginia beach isn't too far. http://67-72chevytrucks.com/vboard/s...threadid=83622
Old 01-02-2004, 11:50 PM   #16
jorgensensc
jorgensensc's Avatar
If you can read the oil filter number, that will identify (if you cross reference it) as a 305. The screw in on it is different than a 350, thus a different oil filter. Also check below the #! spark plug, one of my engines said 5.7 and another had 305 cast in on it there.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-03-2004, 09:09 AM   #17
Frankd
says 305 on the casting on rear of block
72 c-10
81 c-30
67 c-10 just sittin in the woods)
70 C-10 " " " "
to compleete frames 67, 70 - in woods
2002 toyota tundra.
12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker
Frankd is offline   Reply With Quote
Old 01-03-2004, 03:50 PM   #18
1972C10
1972C10's Avatar
Thats awfully funny because Depending on application be it car or truck they use the same identical filter Pf35 for trucks Or the new number pf1218 and the half qaurt for cars same thread same oil filter adaptor housing. only difference is the bore of the engine and the heads other than that gonna use same componets as a 350
Old 01-03-2004, 06:02 PM   #19
Rod
305 has a larger harmonic balancer.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
