Is this where I hook up Vacuum Advance on a Holley 4160?
Holley 4160 Carb (Vacuum Secondaries/Electric Choke/600cfm/"Smog Carb")
Note: Although this is a smog carb, there's nothing smog on my truck... I've had my vacuum advance hooked up in the pictured spot for a while now, and my truck has always had an idle problem. I was at the drag strip yesterday, and a few people had their vacuum advance hooked up in the spot I have an arrow pointed at. So which port should I have my vacuum advance hooked up to? The white circle/blue arrow one, or the red circle/white arrow one?
Formerly yellow72custom
For a vaccum advance there are 2 ways you can hook it up.
1. With vaccum going to the vaccum advance at idle (manifold vaccum) 2. Without vaccum advance going to the vaccum advance at idle (ported vaccum). Pull off the vaccum hose when your truck is idling and stick your finger over the hole...if it tries to suck your finger in, you are running it off of manifold vaccum. If there is no vaccum at the port, it is on ported vaccum. If your truck has a rough idle and the advance cannister is hooked up to the ported vaccum, hooking it up to manifold vaccum will significanlty improve the idle quality. From what i understand, there is no difference in fuel economy or power either way. Try hooking it up to the manifold vaccum port and i bet it will idle much smoother. I'm guessing you have it hooked up to ported vaccum right now (i'm not familliar with Holley carbs).
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Hotwheels?
I asked this question a while back tim. The only thing that full-time vaccum does is help with the idle. I run mine off full time, especially in the winter when its cold. But theres no MPG differences or anything.
1978 Money Pit - CUSTOM DELUXE!!!! |
#4 | |
Hotwheels?
Its definitely more lopey with ported, but in the winter its really not better.
My friends say that my truck idles really high in park and I just tell em its my choke and vaccum. Damned newschool kids and their fuel injection ![]() Im just too cool for school I guess.
#6 | |
Try adjusting your idle with the vaccum guage....i found this is the best way to get a glass-smooth idle. If it is mis-adjusted it will surge alot like you have described.
The only time to use the ported vacuum feature on the carb, would be if you had a functional EGR. (That would be the white circle/blue arrow in your picture).
It's best to run full manifold vacuum to the vacuum advance. The KEY is - you have to either run an adjustable vacuum advance (such as the Crane unit), or limit the travel of a stocker. Obviously, the adj. unit gives you more flexability!! With the vacuum adv. off and plugged - set your initial timing to 10*-12*. Hook up the vac. advance and dial in the advance cannister to give you about 8*-10* more adv. See how that works for you....pay attention to pinging. Next thing to work on is your total timing. You need to see how much mechanical advance you have and how soon it's coming in. I'm more familiar with timing for Buicks - we shoot for a total of 32* or so, and have it all in by 2500rpm. Pretty sure Chevy engines like a little more total timing.
Scott |
#9 | |
I think my idle problem is just my stupid carb (being a smog carb and all). I'm gonna put it on a shelf, and swap in a NORMAL Holley 650cfm 4160. |
![]() Join Date: Dec 2001
the top port is ported vacuum and the bottom one is full manifold vacuum
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
