Old 02-12-2004, 11:22 PM   #1
kilomanjaro
kilomanjaro's Avatar
Frame thickness on 1/2 Ton vs. 3/4 Ton?
I just got a 1/2 ton 4x4 from randy, I got to looking at the frame and it is the same thickness as my buddies 3/4 ton 4x4(as well as all other 3/4 tons I have seen). I know that it is thicker than 1/2 ton pickups, blazers, and suburbans, are 1/2 ton 4x4 pickups thicker than other 1/2 tons. Also the rear driveshaft is about 4" in diameter like a 3/4 ton 4x4, is that normal for a 1/2 ton 4x4? I haven't checked the VIN on the frame to see if it matches the title and VIN plate. Anyhow just looking for someone's input here, I am kind of stumped, other than the possiblity of someone swapping a 3/4 ton 4x4 frame under a 1/2 ton 4x4 pickup I have no answer---thanks
john
63 Buick Wildcat 425
72 Chevy Blazer CST
72 Chevy C10 Cheyenne
00 Ford F-350 Super Duty 7.3L
09 Dodge Challenger SRT-8
10 Ford Expedition Limited
kilomanjaro is offline   Reply With Quote
Old 02-13-2004, 12:04 AM   #2
Gee_Emm
Thickness as in the thickness of the metal. There was a big debate here a year or so ago about that. I think the conclusion was reached that 1/2 ton and 3/4 ton frames are the same thickness. My 3/4 ton frame isnt thicker then a 1/2 ton frame.
Gee_Emm is offline   Reply With Quote
Old 02-13-2004, 12:08 AM   #3
kilomanjaro
frame
Well I don't know about 1/2 ton pickups(this is the first I have ever had), but I know that 3/4 ton pickups are thicker than blazers and 1/2 ton suburbans, and the at 3/4 ton suburban frames are thicker than 1/2 ton suburban frames.
john
72 Chevy Blazer CST
Old 02-13-2004, 03:20 AM   #4
sbrban
My 71 3/4 ton sub frame is same thickness as my 72 1/2 ton sub-I'm pretty sure it's the same as my 71 4x4 and 681/2 tonframes as well-I'd need to double check-tommorrow!
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 02-13-2004, 03:22 AM   #5
sbrban
only difference on 3/4 to 1/2 frames that I found was in the trailing arms and front control arms
Old 02-13-2004, 04:04 AM   #6
kilomanjaro
frame
Just to be clear we are talking about the thickness of the metal used to make the frame, not an actual demension on the frame right? I was almost positive about the 1/2 ton sub being thinner.
john
72 Chevy Blazer CST
Old 02-16-2004, 03:43 AM   #7
sbrban
Thickness was the same.
Old 02-16-2004, 07:39 AM   #8
68 Suburban
68 Suburban's Avatar
I remember looking in the data books and they gave the 3/4 ton frame the same thickness as the 1/2 ton.
68 Suburban is offline   Reply With Quote
Old 02-16-2004, 10:19 PM   #9
Rod
Those big 4" drive shaft for the rear are what are on my 1/2 ton and 3/4 ton 4x4's. Only difference in the truck or sub era I have noticed is that some early 67 and maybe some 68's had a two piece rear drive shaft also. I might have even come across a 69 with a 2 piece rear shaft if I remember right.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-16-2004, 11:03 PM   #10
Blue_71
Bloo
Blue_71's Avatar
my 3/4 ton 4x4 frame is thicker then a parts truck 70 1/2 ton 4x2 frame i have... i cut the frame horns off the parts truck so i could put a bumper on my K20 and when i put them against it it was noticably thinner
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-16-2004, 11:10 PM   #11
jcueckert13
jcueckert13's Avatar
i thought the frames where the same but the difference was in the suspension
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 02-16-2004, 11:18 PM   #12
sbrban
I've only dealt with the suburbans and in that respect,yes, the frames are identical with the exception of the suspension.
Old 02-17-2004, 12:31 AM   #13
Yukon Jack
Mechanically Challenged
Yukon Jack's Avatar
I can't speak to the thickness issue, but the restoration pack from GM says there is a difference in the strength. I can't recall the specific term, it was something like sectional modulous.
1970 Blazer with a 400 sbc and 4" lift Roadworthy!
1969 K20 with a 454, a bit of lift and 35's
1980 Pontiac Trans Am, 455 Oldsmobile
Yukon Jack's Web Pages
Yukon Jack is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
