Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 02-27-2004, 12:27 AM   #1
CRF230Rider
Replacing intake manifold gaskets on a 98 Silverado
Has anyone here replaced the intake maifold gaskets on a 98 or similar model Chevy/GMC truck? Mine has a 5.0 or 305 motor that is leaking coolant badly at the back of the cylinder head at the intake manifold. Everything I've read says to change the manifold gaskets so I guess that's what I'm in for. How long will the job take for average shade tree mechanic, 8 hours?
CRF230Rider is offline   Reply With Quote
Old 02-27-2004, 03:38 AM   #2
99-2door
99-2door's Avatar
8 hours, I would hope not, geez. It took me about 2.5 hours and I wasn't really in a big hurry. I do work with these trucks a lot though.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 02-27-2004, 10:53 AM   #3
bpmcgee
bpmcgee's Avatar
If you've never done it before, leaving yourself a full day (8 hours) isn't a bad idea. Especially on the newer vehicles, there are a LOT of wires up top.
Take your time as you disconnect things. Either take digital pics as you go or use tape and a sharpie to mark wires and hoses as you disconnect. TRUST ME, every minute spent documenting will save you an hour of puzzling over wires and hoses as you put it together.
Although leaving yourself a full day is a good idea, I'd guess if you're careful and good with wrenches, you'll be done in time for an early Beer O' Victory!
Brian
1961 GMC Suburban
bpmcgee is offline   Reply With Quote
Old 02-27-2004, 03:53 PM   #4
kaycee
kaycee's Avatar
Angry Me To
Looks like I'm going in that direction too seen a small spot of coolant on the garage floor yesterday.
2001 Silverado K-1500
2005 FXDWG stage2
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60/3:36
kaycee is offline   Reply With Quote
Old 03-03-2004, 02:16 PM   #5
kxmotox247
kxmotox247's Avatar
There must have been something defective about these gaskets from day one.
My intake manifold gasket went out when the truck had less than 50K on it. Right in the back on the left bank head.
It took my buddy about 3 hours and he was a licensed GM mechanic at one point. He said he had never seen a gasket do what mine did and he felt it was probably defective to begin with.
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=652776
kxmotox247 is offline   Reply With Quote
Old 03-04-2004, 02:31 PM   #6
graywolf
i have alot of friends who are mechanics, and it seems intake manifold gasket failure is very common, in all vehicles, soom think its something with the newer long life coolant, anyone else hear that?
graywolf is offline   Reply With Quote
Old 03-04-2004, 02:46 PM   #7
kxmotox247
kxmotox247's Avatar
Yep...i forgot to add that to my last post. I've been told that the dex cool crap is damaging the gaskets as well as slowly eating away at the freeze plugs.
My Build Thread:
Old 03-04-2004, 05:48 PM   #8
graywolf
couple shops that i know of are flushing cooling system and installing the green antifreeze after replacing intake manifold gaskets, oh yea and don't ever mix the two together, it'll turn brown, and i heard the two mixed break each other down so that the lubricating value for water pump won't be there
Old 03-04-2004, 05:56 PM   #9
graywolf
gm and ford also say do not use the 3m roloc fiber pads on a angle die grinder to remove gasket material on aluminum surface, ford says use plastic gasket scraper, gm says you can use die grinder with white roloc bristle disc,120 grit
Old 03-04-2004, 08:47 PM   #10
99-2door
99-2door's Avatar
I've never had a problem with the intake gaskets on one of these trucks. I had to change the intake cause of one of those stinking water fittings.
Old 03-15-2004, 10:32 AM   #11
97Silverado
This problem is due to the fact that these gaskets are overtorqued from the factory. To date I have done about 8 of these.
97Silverado is offline   Reply With Quote
Old 03-15-2004, 11:43 AM   #12
jsledder
Watch out for the water fitting on the intake, you will probably end up breaking the nice little plastic piece that holds it in there, you just as well go down and buy a new fitting at NAPA before you get started (8-9.00). The wires and everything look intimidating, there is really nothing to it, the wires will only plug into one fitting so you can't screw it up that way. Make sure you get the distributor marked and back in right. I used carb cleaner to clean the intake off inside and out and it cleaned up like new with no scrubbing, took about 10 cans though.
Good Luck, I tied up most of a weekend but I took my sweet time and cleaned everything up real good.
www.outdoorsupplyonline.com (snowmobile and atv parts)
www.ipsindustrial.com (industrial tools)
jsledder is offline   Reply With Quote
Old 03-15-2004, 02:46 PM   #13
STEVE A WILBURN
YOU KNOW CHEVY IS GOING DOWN HILL IT LIKE MY PAINT ONE DAY JUST STARTED TO FALL OFF, I THINK GM SHOULD BE MADE FIX BAD PARTS AND PAINT, I KNOW I WONT BUY ANOTHER CHEVY
JUST HAPPY TO BE ALIVE.
STEVE A WILBURN is offline   Reply With Quote
Old 03-15-2004, 09:31 PM   #14
jsledder
And no other brand ever has a parts problem???
Old 03-16-2004, 10:25 AM   #15
kxmotox247
kxmotox247's Avatar
No kidding! My neighbor's Fords are constantly giving him problems. One thing after the other.
My Build Thread:
Old 03-16-2004, 10:34 PM   #16
bwood
bwood's Avatar
The intake gaskets on mine were plastic and had an o-ring embedded in them for the seal. The mechanic was suprised to see that they made it that long (70000). The new ones are the same and he blamed it on the gaskets themselves, the plastic gets harder and ridgid from the constant warm up and cool down and eventually breaks (he said 99% of them in the same spot on the back passenger side). Usually it shows up in the winter around here. Good luck they had mine for a day.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 03-20-2004, 03:46 PM   #17
MarkMagwire
Just out of curiosity, did you have a dealer work on it? If you don't mind me asking what did they charge?
MarkMagwire is offline   Reply With Quote
Old 03-20-2004, 07:04 PM   #18
bwood
bwood's Avatar
I had the dealer work on it, it has an extended warranty through GM so it only cost me $50. I did ask though, they said between $600-$700. After I woke back up (from the shock) they told me it was an all day job. A local mech told me he normally does this for around $350 - $450 including replacing the nipple in the intake.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 03-21-2004, 11:25 PM   #19
1FaastC10
1FaastC10's Avatar
DO NOT USE PARTS STORE GASKETS! use genuine GM gaskets, they're thicker and will seal better than anything out there.
1FaastC10 is offline   Reply With Quote
Old 03-22-2004, 02:33 AM   #20
97silv5.7
MooMoo
97silv5.7's Avatar
Wondering how long do those gaskets last? my 97 has 51k on it and its still nice and clean. Just wonderin so ill be prepared. Thanks
97silv5.7 is offline   Reply With Quote
Old 03-23-2004, 11:50 PM   #21
MarkMagwire
Good question '97. My '96 just turned over 100k and it sounds like I'm one of the fortunate ones. Good luck with yours.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
