Old 03-24-2004, 08:45 PM   #1
daddybullfrog
Active Member
daddybullfrog's Avatar
Cam gear removal 250 Inline 6cyl
The timing gear on my '67 6 cyl bit the dust. I have been able to remove the crank gear with a puller, but the cam gear has no threaded holes to attach a puller. How do I get this thing off?
It is a fiber gear and the replacement set is all metal. Any help will be appreciated.
'67 C-10 short stepside
'72 K-10 Cheyenne Super under construction
daddybullfrog is offline   Reply With Quote
Old 03-24-2004, 08:59 PM   #2
Gordo
Smile
I believe you need to remove the camshaft retaining bolts through the holes in the gear then remove the camshaft with gear attached and then press it off in a press. Same goes for the install, it's pressed on.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 03-25-2004, 01:03 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
The new gear should have installation instructions with it. To install the aluminum gear you need to heat it hot enough to burn your fingers and it should go on without a press. Using a press will shave off metal you need for the interference fit. Most guys either heat in an oven or on a hotplate. A propane torch will work in a pinch, but isn't recommended. Let it air cool after assembly.
There is supposed to be a specific gap between the gear and the plate, but I don't have a manual at work and can't remember what it is.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-25-2004, 09:35 PM   #4
daddybullfrog
Active Member
There were no instructions with the new gear set. Can I heat the old gear to remove it? The way it looks to me, I'll have to pull the motor to pull the cam as there doesn't seem to be enough room to pull it while the motor is still in the truck.
Maybe some old timer can suggest a way to pull and re-install the gear?
When I was a kid we had a chev 216 drop the timing gear and I'm pretty sure the mechanic did not remove the cam.
Old 03-26-2004, 12:07 AM   #5
NeCrOmAnCeR
Run her till she blows!!!
NeCrOmAnCeR's Avatar
I've drilled a series of small holes in the metal portion of the gear in a straight line going out from the center. (be careful of where the metal goes, and also don't get to close to the cam). Then take a cold chisel and split the metal ring. Then as posted above, heat the new gear and slip it on (you have to be quick so it remains hot).
NeCrOmAnCeR is offline   Reply With Quote
Old 03-26-2004, 03:46 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
If you need more access you can unbolt the engine mounts and jack the front of the engine up.
I haven't tried swapping the timing gear with the cam in the vehicle. You would have to be careful about getting the timing marks lined up. There is a woodruff key on the cam that comes into play. You will also need a long feeler gauge. End play, clearance between the cam gear and thrust plate needs to be set at .001-,005.
And remember, you only have one shot at doing this right and you will have to work fast. If it were me, I would pull the cam.
Fred
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
