Re: Wizit's bagged 60 gmc build
I was planning on getting new ubolt anyways so I was hoping there might be some that already meet my needs. If not you can bet I will seeing if I can thread them further. |
Its been a crazy busy summer and I finally got a few minutes to work on the truck last night.
I picked up some Slam Specialties ss-7 bags for the front. Got the front wheels and tires on and the upper arms pie cut and rewelded to keep from maxing out the ball joints. http://i84.photobucket.com/albums/k1...722_203948.jpg Added some quite gussets on the top of the crossmember for some strength and looks. http://i84.photobucket.com/albums/k1...722_212014.jpg Im hoping to pick up my rear tires tonight and I will have all the wheels and tires on. Ended up with some 285/30r20 on front. they are a little small but my tire sponsor had them laying around so ill give them a try. The rears im picking up are 295/35r20. Im hoping to have the frame painted up and the cab back on soon! |
Sweet! Looking good!
Looks great!
I just found this build thread.......Welcome to the forum neighbor :) You're doing some nice work.
Nice work! You're making it look easy.
Did a little more work on the rear of the frame.
I took my time on the trac bar and employed some of my suspension geometry knowledge from the offroad world. I was able to get away with only 1/2" of side shift throughout the suspension travel range. Im happy with that! http://i84.photobucket.com/albums/k1...821_204917.jpg added a little bit of tube work and some filler plates. Note: the filler plates are unfinished. they will be received some dimpled holes. http://i84.photobucket.com/albums/k1...823_172330.jpg http://i84.photobucket.com/albums/k1...823_175719.jpg Im going to run some tubes down to tie into the lower rear part of the c-notch to add some strength to the trac bar mount as well. Then bag and shock mounts and the rear will be done! Speaking of which. any shock recommendations?? |
Great work, Welcome.
Sub'd |
Very cool. Planning something similar on my 63 whenever I get done with the 68 i'm currently doing.
Got some shock mounts done last night. went with a "hidden bolt" design on the upper mounts.
Im not happy with the plate on top that connects them. It will be replaced with a curved plate that mounts only to the outer piece of tube. http://i84.photobucket.com/albums/k1...824_210503.jpg Im considering ditching the panhard and building a Watts link. I was looking at the back of the frame and just think it would look really good back there. I really like the uniqueness of the Watts Links and how everyone builds them a little different. Heres is what i drew up real quick for the center section. :metal: http://i84.photobucket.com/albums/k1...MC/Capture.jpg |
So much easier to fab using a 9" rear. But it looks like you're up to the challenge either way. I somehow missed your thread until now. Nice work! You're making good progress. |
I like the Watts link also, but have yet to fab one up. That would be so nice to be able to draw things up in Solidworks. I'm limited to just 2d CAD.
Here's the updated model. http://i84.photobucket.com/albums/k1.../Capture_1.jpg |
Had a busy weekend and got some work done on the truck. Also helped a buddy out and built him some nice inner fenders for one of his cars.
The weather has cooled down a bit so I can work at a slightly higher pace now. Built some new braces for the shock mounts and finalized the location of the bag mounts. Got the frame plated and the mounts all welded on. Still need to add gussets. http://i84.photobucket.com/albums/k1...828_190025.jpg http://i84.photobucket.com/albums/k1...828_190037.jpg I dusted off the bead roller and rolled a nice offset pocket in the filler plates. Really happy with how that came out! http://i84.photobucket.com/albums/k1...829_004621.jpg Quick vid of airing it up about half way and dropping it back down. :metal: http://i84.photobucket.com/albums/k1...GMC/th_yea.mp4 I started working on the front suspension. I didn't like the idea of building such a large "cup" in the lower arms as I was going to need so i started looking at other options. One thing lead to another and I ended up completely rebuilding the upper arm mount and building a raised bag mount. I didn't take as many pics as I should have. Trimmed the crossmember back to be flush with the frame. http://i84.photobucket.com/albums/k1...830_182040.jpg Started making some templates http://i84.photobucket.com/albums/k1...830_190211.jpg Ended up with this. New grade 8 bolts to replace the studs. captured under the doubler plate and welded on the backside. I will take more pics of this when I build the other side. Still needs some cleanup but the main portion is done. I angled the bag mount to be parallel to the bottom of the lower arm at full compression. http://i84.photobucket.com/albums/k1...831_183046.jpg http://i84.photobucket.com/albums/k1...831_183042.jpg Threw the suspension back on to measure for the lower bag mount. http://i84.photobucket.com/albums/k1...831_182603.jpg Lower arm cutout and filler plate tacked in. Bag fits perfectly! I love it when my math works out. I still need to box the arm back in and dress it up with some fancy gussets. http://i84.photobucket.com/albums/k1...831_192258.jpg |
Heres some pics of the friends car i worked on. High clearance inner fenders for a 240sx drift car.
http://i84.photobucket.com/albums/k1...23271214_o.jpg Painted up. http://i84.photobucket.com/albums/k1...86806477_o.jpg Also helped him with some assembly of the Ls that will be going in the car. http://i84.photobucket.com/albums/k1...83602495_o.jpg |
New suspension is looking good.
dont you want the bag mount to be parrallel to the control arm at ride height? not deflation height? Im sure it doesnt matter that much. but wouldnt it matter less when there is no force on the bag as opposed to at ride height when the weight of the truck is bouncing on the bag?
The way I understand it is that the bags have a sort of internal bumps stop and that the plates of the bag need to contact each perfectly flat if they are ever bottomed out. If they contacted each other at an angle it could cause damage to the bag. |
I finished up the other side of the front suspension last night. it felt really good to be able to air up the front and back!
http://i84.photobucket.com/albums/k1...901_213847.jpg http://i84.photobucket.com/albums/k1...901_213800.jpg http://i84.photobucket.com/albums/k1...901_213754.jpg |
Lots of really cool fab!! You should make two of those watt's links and send me one....
Good work never is. It was worth a shot! hahaha
