Re: Boyd Tank Installation
https://gmcpauls.com/fuel_tank_&_related.htm |
According to this thread, the cab holes are the same size.
https://www.67-72chevytrucks.com/vbo...ad.php?t=26676 |
One thing I didn’t “get” with this install is that aeromotive recommends 10g wire and a 30amp fuse (even though they say the pump only pulls amps in the teens), yet the pigtails from the actual in tank pump are 14g, which you would think would be a concern if the wire actually saw anything near 30amps. Then it brings up a question of whether a weatherpak connector is appropriate as they are only rated to 20amps (but a metri-pak is good to 30). Probably overthinking it here.
Posted via Mobile Device |
http://67-72chevytrucks.com/vboard/s...d.php?t=829199 |
Thanks for the write up. I was just thinking about doing an electric fuel pump upgrade on my existing boyd fuel tank this winter.
I replaced the 30A fuseholder so the wire isn't getting pulled tight.
I'm staring the process right now. Helps so much thanks
I filled my tank up all the way for the first time today, and it was leaking from the top. I jammed my arm in there from the wheel well and felt around. The top of the fuel level sensor felt wet. I jacked up the driver side of the truck and put jack stands on that side only so it was tipped way to the right. I used an inspection camera to take a look, and there was fuel trickling out of the cube shaped piece on the top of the sensor that the cable comes out of. I will be calling Boyd's in the morning. I'm not looking forward to emptying and dropping the tank. Here's a video that shows the leak.
https://youtu.be/Yi5TRk_VtoY |
Nice work....too bad a brand new tank leaks...
I have about the same set up on my '67 with LS1 swap I put an inline filter in the frame rail up close to the engine Attachment 2156438 |
man, that sucks! Hope Boyd's works with you on a solution!
Keep us updated. I always say the true measure of a vendor is what they do when there is an issue.
That's good news (and bad) .... bad that you have to drain and swap it out! Practice makes perfect, I guess.
That's a good vendor for you. Sorry for the trouble though.
Following this thread. Just ordered my Boyd tank yesterday.
Thanks for all the detail! |
That's odd. The sending unit on my Boyd's tank doesn't have that square part on top. Only the 2 terminals for wires...
I wondered if they have started using a different sender. |
