Re: Boyd Tank Installation
I feel for you! and surely don’t like what I am hearing. Maybe put a little #2 permatax on the bolts, should not have to do anything to the gasket. I like to use just a little Vaseline on new gaskets. It helps them adhere to the metal. But used you might have to use #2 permatax as well. Good luck with it. Thanks Chuck
Posted via Mobile Device |
Off topic question but I’m at this point with my Boyd tank install… How did you go about cutting the hole in the bed to ensure everything is lined up correctly? Was bed on or did you just take a lot of measurements and cut the hole with it off, or start with a small hole so you could see how it is lined up?! Figure I would ask someone who has done it.
I went with side fill, fill spout behind taillight. Thanks Chuck
https://67-72chevytrucks.com/vboard/...47&postcount=5 |
5 Attachment(s)
I dropped my tank this evening to put thread sealant on the pump mounting screws. While I was at it, I rerouted the vent hose to the rear left stake pocket. I installed a Dorman 924-284 vent on the end of it to keep water out.
I wasn't going to put anything on my Boyd's tank rollover vent. Maybe I didn't read the instructions. Is it necessary to put a hose on there?
If the tank was pressurized then the new vent on rollover valve probably eliminated the leaks. Glad you got it fixed, now go out and have fun with your truck! Thanks Chuck
Glad you got that solved and won't catch on fire! :-)
I suppose that was a bit of an understatement!! Who the heck wants to catch on fire... well unless you are Metallica ha!
Oh, I know the feeling (smell, not risk of fire).
I went on a whole mission in restoring my charcoal canister a year or so ago that my brother fudged up and said I really didn't need it. Funny thing, now in the for sale forum there has been tons of them for sale (even NOS I think). Oh well, I know how to pull it apart and "recharge" it now. So I guess that is a win ;-) |
100% gone - like poof! That thing works I tell you.
2 Attachment(s)
Just got back from a 5-day trip and there is a little puddle if gas on the floor under my tank. I think it might be coming from the fuel pump. I'm getting tired of this issue.
I can’t imagine what you are going through, you are getting to be an expert of your tank removal for all the wrong reasons. I guess give Boyd a call? Hang in there and thanks again for the update. Thanks and be safe. Chuck
The fuel is somehow wicking down the wires from the sender and pump. It could be that I have a leaky fuel hose fitting that is dripping on the wires. I ran the pump for about 5 minutes and I did not see or feel any fuel leaking anywhere. It does seem to be related to having the tank so full that fuel is inside the filler neck. It sure would be a whole lot easier to diagnose this if the bed weren't installed.
Sorry to hear about all the trouble. One of the reasons I relocated the tank was to solve the gas smell issue. Day after I installed my Boyd tank the wife asks if I spilled gas in the garage. I go out and the garage smells worse than when it had the cab tank. If I plug the roll over vent line smell goes away so I know it is coming from the rollover tube. I have been following this thread to see if you had the same issue. It is my understanding a rollover valve will allow your tank to breathe and not build up pressure or vacuum during normal operation while serving as a safety in case of rollover. As fuel is drawn from the tank, the rollover valves allow air to return to the tank so a vacuum situation is avoided. Wouldn't adding the Dorman axle vent prevent the rollover valve from allowing air back in the tank? I believe axle vents are just one way valves designed to prevent pressure from building inside your axle. I assume this would cause your tank to go into vacuum as the fuel is consumed.
I almost purchased that axle valve but now I have come to the conclusion a charcoal canister may be the way to go. I hope you get your leak solved. Seems like for every one step forward I take four steps back with this truck. Guess that's the cost of being so damn cool. At least that's what I tell myself. |
Thanks for the info pjmoreland! Sounds perfect for this application.
I have a couple sets of the mounting studs available that I used to mount my tank:
https://67-72chevytrucks.com/vboard/...d.php?t=829891 |
3 Attachment(s)
I've continued to have the issue where fuel would seep out of the tank somehow when the tank is completely full even after I put sealant on the pump and sender mounting screw threads and tightened them down securely. I believe I have found a solution. I think this seepage has been happening due to pressure building up in the tank and having no way to get out. The roll-over safety valve I ordered with the tank that was installed in the vent hole appears to have a check valve inside it, in addition to the loose fitting check ball. This internal check valve gets stuck shut if anything tries to flow out of the tank. It takes a surprising amount of pressure in the direction into the tank to open this check valve once it has closed.
I replaced the safety roll-over valve with an open fitting this evening and then drove to the gas station and filled my tank as full as I could get it. I have been watching the tank for an hour or so now, and no fuel is seeping out anywhere. Since my truck has a carburetor, the fuel floats would allow fuel to drain out of the carb in a roll-over, so I'm thinking I'm not really giving much up safety-wise, by eliminating the valve. |
