EFI fuel plumbing
I am setting up my fuel system on my truck and I am running the MSD Atomic EFI with the external pump. The tank is frame mounted and only has top fittings. I know the in-line pumps are supposed to be gravity fed but has anyone ever heard of using a dry lift pump to feed the EFI pump? I have a Holley Blue pump to use but not sure if that'd work.
Re: EFI fuel plumbing
