Single wire alternator not charge
5 Attachment(s)
Looking to get some advice on a charging system. previous owner did the single wire upgrade to the 64 c20 that we picked up. All the wiring looks correct and there is a resistor under the dash that is lighting up with no issues. Everywhere we test we only get 12.4v going back to the battery.
Replaced a few ends and cleaned up the terminals but no change. Alternator was bench tested at Oreilly's with no issues. Brown, blue, and white wires that went to the old external regulator are not connected to anything as described in previous posts. We put in a new battery, but the old battery had the same amount of voltage. Any suggestions on something that needs to change or check? Thanks! |
Re: Single wire alternator not charge
While it's running the alternator power wire should be seeing between 13.8 and 14.2 volts. I have heard the 1 wire alternators require the engine to reach 1000 or 1200rpm before the alternator will start to charge?
I would let me move this to the electrical section also. https://67-72chevytrucks.com/vboard/...splay.php?f=64 |
I do see a couple of threads now stating it needs to be over 1000 rpm to charge.....something I wasn't aware of.
We did increase the motor speed multiple times with no change. |
64 c20 Single wire Alternator not charging
5 Attachment(s)
Replaced a few ends and cleaned up the terminals but no change. Alternator was bench tested at Oreilly's with no issues. Brown, blue, and white wires that went to the old external regulator are not connected to anything as described in previous posts. We put in a new battery, but the old battery had the same amount of voltage. Any suggestions on something that needs to change or check? |
Re: 64 c20 Single wire Alternator not charging
Could the issue be that the previous owner connected the red lead directly to the power output on the back of the alternator instead of going to the junction on the core support?
A true 1 wire alt doesn't need that white 2 wire connector. If yours does, then it is a standard alternator. Try running the red voltage sense wire to the junction box(if present) or to the battery. Yes, that means you will have both red wires going to the same place but that is how the 10/12 SI internal regulated alternators are designed. The red voltage sense wire picks up the voltage from where it is connected and adjusts the output of the alt to reach the desired voltage at that location. This lets it cancel out any voltage losses in the main charging wire.
Thanks! Will give that a try.
When I installed mine there was a plug that used to connect to the external regulator. When the regulator was removed I had to install a cap on that plug that rerouted the wires. It looks like a lot of those wires on your truck were cut instead. I don't know that those wires were for but it might be something you might want to look into.
the white wire in that plug makes the alternator start charging immediately instead of having to hit 1000 rpms to start charging, if it were mine, and it was cause I just went thru this with a newly installed 160 amp , Id double check the ground, over time you will like the instant charge function that that white wire provides
Ran the red wire coming out of the battery and still only getting 12.43 v coming out of the alternator and at the battery. Will start taking more apart but assuming doming isn’t causing the regulator to send voltage.
Thoughts? |
Just out of curiosity what would be the alternative to the yellow crimped on terminal? Does it need to be soldered and shrink tubing applied?
Redid all of the terminals and validated everything was correct and now it’s charging under acceleration. Thanks for all the input.
Glad to hear it. :)
Go to the home page of this forum and check my Electrical Faqs and look at the threads on
converting to an internal regulated alternator. Also look at the thread on why won't my battery charge. |
Replaced a few wires and connections. Battery is now charging under acceleration! Thanks for the advice.
