1972 K20 hydraulic clutch conversion
Putting a 5.3 in a 72 K20 with a sm465 4spd. I know I need to convert to hydraulic clutch to eliminate the z bar linkage. At one point I had read you could us Advance Aadapters bracket #715535 on the original cast bell housing, but can't seem to find this info again to confirm before I start purchasing parts. Anyone that has done this that can chime in?
Re: 1972 K20 hydraulic clutch conversion
Yes, you can do this. I did this with my 66 K20 down in sig below. The part number you want is 716287.
Ok, thank you. What slave cylinder did you use with it?
Here is the whole setup that I used -
https://www.summitracing.com/parts/add-716287 https://www.summitracing.com/parts/add-716116 https://www.summitracing.com/parts/wil-260-6766 |
Thank you, appreciate the info!
