Post your GM part numbers here
I figured we should have a thread for factory part numbers for easy reference. Anytime you get a receipt from the dealer try to list the part number and name of part here. It doesn't matter how small the part is. It may help a fellow board member who is looking for an "oddball" part!. Lets try to keep this as simple as possible. Heres a few I have bought for my 70'. I hope these are valid everywhere, otherwise this post is useless.
Upper steering column bearing - 5679205 Chrome turn signal lever - 3909580 Turn signal switch - 1972751 Turn signal switch harness assembly for the above switch - 1894851 Turn signal cancel cam - 3902190 Detent seal for detent cable - 1262475 (350 turbo) Transmission filler tube seal (top hat later style) - 1259475 (350 turbo) Transmission filler tube seal (O-ring earlier style) - 6264902 (350 turbo) :flag: :bowtie: :canada: |
Exterior door handles
#3927899 and #3927895 I read this on another post, can't vouch for it and I don't know which is left or right. |
For 1973 1974 1975 1976 1977 1978 1979 1980 (as far as I know)
Fender right 14031990 Fender Left 14031989 Hinges 6262007 & 626008 Hood 15576465 passenger bedside 15597624 |
Here's the upper alternator mounting bracket for 67 thru 72. Still available as of this posting...... 3951338
Steve |
That bracket is the adjustment arm and for the drivers side and for a short water pump....
Re: Post your GM part numbers here
plug in harness for van tilt to 67-72gm no.1894851 flat to horseshoe
73-87 headlight switch GM #1995217
GM PartsDirect has it for $16 Classic Industries has it for $30 |
Don't know if you can still order these but here you go:
3917809-stainless cab trim-under the back window 3997463-Longhorn upper bed pass. side molding..pic included |
73-80 (may be full run to 87, not sure) Roof Marker LENS 7505068
GM must have changed #'s again, the 5 cab light lenses I bought for my truck are part #684662 in the new style box. Here's some more in case you guys need specific ones:
Roof marker lens gasket, 69-72 Gr. 2.575-#12337943 (new # should be availbile at your dealer, old one is 3942898) Window regulator handle, 69-72 Gr. 10.797-#20348200 Gas tank neck grommet, 67-70 Gr. 3.008-#3886792 - this is a good # that any dealer should be able to get Winshield wiper switch, 2 speed, #1993432 Door handle escutcheon(black, paint to match), Gr. 16.270-#3939997 Brake light switch, Gr. 2.4447-#1261219 Windshield washer hose grommet(goes on firewall), #3746483 Interior mirror cover(usually black, I have two NOS and one is dark metallic green from GM), 69-72 Gr. 16.069-#3971007 Heater control switch, Gr. 8.852-#3840039 Hockey puck cab lens, 69-70 #5961757 Rear red sidemarker light, 69-72 Gr. 2.575-#916087 Front amber sidemarker light, 69-72 Gr.2.575-#915788(had three #'s on the box, all crossed out except this one) Clutch rod swivel, 67-72 Gr. 0.787-#3918467 Deluxe Delco radio knob, 69-72 #1991087, also has 1991072 on the package |
Sport mirror part #'s. The mirrors and gaskets were still available thru GM about a month ago.
Left side mirror - 3981409 reinforcement - 6263291 gasket - 3987127 Right side mirror - 3981410 reinforcement - 6263292 gasket - 3987128 |
http://67-72chevytrucks.com/vboard/s...d.php?t=216274 |
Eaton 12 bolt car or truck posi. These are the only parts that are the same between car and truck posi.
Eaton posi clutch pack. 12524505 Eaton posi springs Green 50lb 3890899 |
