shift kit install........stalled!
went out to the truck today all fired up to do the shift kit in my th350.lo and behold, i found that the front 2 bolts that are on the pan are blocked by the tranny cross-member.rest of the bolts no prob.dang,dang,dang!ain't no other way of doin' it neither,and you need to support the tranny when you get the cross-member of or you'll damage you're distributor!!ain't it always somethin'??ok,i'm done now!just a word to the wise,if anyone is gonna do this.
------------------ '68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.no rust of the notorious mid-west on this one! see my truck at free photo-i under "'68 chevy truck" |
hmmm,that is a problem. did you install the th350 after it had a stick shift? because i just converted mine from 3 0n the tree to th350 and i hade to remove that front xmember,and i had to use a rear xmember,if yours is supported by the front stickshift xmember,do you have a dustcover on and is it hitting the bellhousing? these are just the probs i had,so i removed the front xmember.
.02 SC ------------------ www.superchevy.cjb.net ---------------------- 1972 Custom Deluxe/10 mild 350: Hedmen headers and dual 3" exhaust ,harlin sharp roller rockers ,MSD ingnition ,Mallory dual point K&N 14x4 air cleaner ,Holley 600 4bbl ,Edelbrok Proformer intake TH350 with lock up verter and 1600 stall American Racing 15x8.5 and michelan 28x8.55 ---------------------- Lorain,Ohio 44055 CHEVY makes HORSEpower,while ford makes ponypower Bowtie or nothing! |
Just unbolt the mount, and jack up the tailshaft a little. Then you'll be able to slip a 1/4 inch drive rachet in there to lossen the offending bolts.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
Ran into the same problem when I went to change the fluid/filter on my TH-350. Managed to fit an open ended wrench up in there, and got 'em off with a lot of patience.
yup,longhorn thats what i'm gonna do when i get a little more time.just thought i'd let others know if gonna attempt sameo.
------------------ '68 swb 350/350 w/edelbrock total performance-performer pkg.ceramic headers,2.5" delta-flow 40 series flowmstrs.no rust of the notorious mid-west on this one! see my truck at www.freephoto-i under "'68 chevy truck" |
