Lower A-arms
Is the lower a-arms the same on a 69 1/2 ton with drums as to a 72 1/2 ton with disc? both 2 wheel drive.
Also is it correct that the sway bay will fit from the 69 to the 72. |
the big steering stops welded to the lower arms will probably ot be locate din same place from a 69 to a 71, a tape measure will tell you that or not.
no other differences however, and 73-up arms with the rubber bushings will bolt under your truck too and any sway bar up through 1 ton will bolt onto your truck from '64-87 not van ones though happy swapping |
