Project: white knight 1967 step
Well here's my build thread for a 1967 short step I bought from spraybomb and his dad Lee out of the classifieds here . I had talked on and off with them for about 2 months and finnally went and got it . I made the 4 hour drive on wendsday the 23rd . I left @ 7:30 am and got there just in time for lunch . It had rained on me most of the way up , but luckily was pretty dry at there place . I loaded up and chated with these 2 for about an hour and a half . Everything was as described and these guys are just plain into cars and are good people . Anyway it's a 250/6 , 3 on the tree , one wheel peel base model . My plans for upgrades include , 6 lug power disc conversion , power steering , built 355 v8 , th 350 2200 stall , posi unit , 2 and 4 ( or something along those lines ) drop , and A/C intall . The 6 runs really good . I changed the oil , repaired the choke cable , and repaired some chaffed wires for lighting and heat blower already . it needs a door and a fender , but the rockers and cab corners are solid . Here are a few pictures . I'll try and keep them coming with updates , as i would like to drive this to the Houston area meet coming up .
http://i47.photobucket.com/albums/f1...ytruck0008.jpg http://i47.photobucket.com/albums/f1...ytruck0010.jpg http://i47.photobucket.com/albums/f1...ytruck0014.jpg |
Re: Project: white knight 1967 step
Nice score......
:agree: That looks solid! Always good to have more '67 stepsides on the board.
That Truck would Loook Nice with a Shop Logo on Door's , Dropped & Left as Is...........
Rick |
Sweet ride. Are you going to keep the spare tire rear fender? I think those look pretty cool. Keep us updated. Nice to see another '67 short-step getting redone!
D |
Toomanytoys I like the look it has now , but unfortunately that is not an option . Im less than 2 miles from Galveston bay so that surface rust will turn into a real mess pretty quick . I've got to paint it .
Richard the spare will stay on the bed . My short term plans are to find a 5th ralley wheel and tires for it . This weeks project will be the 6 lug disc brake conversion . The brake are not working so this will be first on the list . I bought 1989 chevy spindle assembly and 1978 booster and master cylinder . I have the 3/4 ton lower arms and all new ball joints and tie rod ends for the swap . I will follow that up with a rear brake rebuild , and a manual proportioning valve for the rear brakes . I will have new tires put on the painted rims tommorow . I also have located 3 center caps and the tire guy says he has the 4th one . Also got the power steering box cleaned up tonight . The donor truck I got the control arms off of has the door and fender I need . Here is the brake stuff for the swap http://i47.photobucket.com/albums/f1...ytruck0004.jpg |
looks nice.... looks like a nice red one in the background too
Nice and clean. Just the way I like my trucks. Good luck on the build. :metal:
Bump !!!
O.K. The power 6 lug disc brake conversion is done , so it has brakes now . I put a turbo muffler on it so my wife will let me run it . The 6 cylinder HEI conversion is done and I bought another carb off a board member as mine still has a stumble to it after the rebuild . I am doing body work right now , as it is sceduled to go to the body shop on friday for new gm pure white base / clear job . Fixed the gas gauge , Adjusted the shift linkage , removed old floor mat and vacuumed in the cowl . Looked like a birds nest in there . Pulled the old plywood bed floor out . Removed the windshield . Pulled the 71/72 front bumper off . Basically preping it for paint . I also found a front sway bar today . The motor will eventually ( it's at the machine shop ) be a .030 350 chevy . This is a roller cam 1 pc rear seal block . I have forged flat tops for it . The heads are a over the counter 1969/1970 double hump , these are the heads you would get if you ordered a performance package with your new Camaro back them they would have come in the trunk with intake , carb , and headers . They have never been installed and have assesery holes . I bought a comp hydraulic roller , it's 208/218 @ .050 and 495/.503 lift . Holley 600 , weiand dual plane intake , and HEI dist . I bought a van tilt from another member . Had a turbo 350 out of a 69 Camaro and a 2200 stall . A buddy of mine just bought a truck like ours and it had new headers on it ( he's going big block ) so I got those . I have all the parts , I just got to find time to assemble this thing . My wife has the camara with her at Disney in Orlando , so i'll get some progress pics up within the next couple of days as she gets home tonight . I drove a 1969 short fleet for about 4 years and wish I would have never sold it .
Sweet !!!
It has brakes ??? you do know those are overrated right ??? |
Looks like a nice truck to start with for sure :D
Here's were i'm at .
http://i47.photobucket.com/albums/f1...ytruck0001.jpg It did not make it to the body shop today . I delayed it for a week . I was able to save the drivers door . http://i47.photobucket.com/albums/f1...ytruck0002.jpg Disc brake conversion is done . Body work continues . I'll try and post a few more pictures later . |
AAAAAAHHHHH !!!!!
The Patina... it's gone !!!! Well I hope it looks good once painted, the patina on it was kinda messed up anyhow cuz of the body damage Can't wait to see it on the road :metal: |
Did you get new tires & paint those wheels ???
And why is your tie rod upside down ??? Hows the hood, you get it fixed ??? |
The spindles are 1989 7200# 6 lug 3/4 ton and use the same year tie rod end. The hood still needs some work . I bought a 78' Z-28 scoop for it to cover the dents in the center feature . I 'll post some pictures so you can get an idea of what im tring to do . |
Hey if you ever decide to sell it....
Ok, Sounds good
Here are a couple more .
http://i47.photobucket.com/albums/f1...ytruck0004.jpg http://i47.photobucket.com/albums/f1...ytruck0005.jpg http://i47.photobucket.com/albums/f1...ruck0004-1.jpg http://i47.photobucket.com/albums/f1...ytruck0011.jpg This is kinda the the way I am planning on doing the hood . Opinions on this are valued . It is a 1978 Z-28 hood scoop . http://i47.photobucket.com/albums/f1...ruck0001-1.jpg And my other project . http://i47.photobucket.com/albums/f1...ytruck0013.jpg |
My opinion is that I WANT THAT CAMARO !!!!
And that hood scoop is gonna be cool |
Roland, remind me what it takes to do the brake conversion if you will
Matt |
Joe , it's a 1968 Camaro RS . 327 , 4-speed , 3.31 10 bolt . This is the car i have always wanted . I have to many projects .
1978 Chevy luv 1968 Camaro RS 1967 c-10 1949 3100 5 window Here is the camaro motor http://i47.photobucket.com/albums/f1...camaro0001.jpg The luv http://i47.photobucket.com/albums/f1...1Image0040.jpg Ya'll know about the C-10 . Here's the 49' http://i47.photobucket.com/albums/f1...9chevy0006.jpg The disc brake conversion is the one in the FAQ section . 3/4 ton lower arms with 90' lower ball joint , 90' 7200 # 6 lug rotors , spindles , and calipers . 90' 1/2 ton upper ball joints in stock upper arms and 90' tie rods with es2020r inner tie rod ends . |
Bump for progress !!!
Well it's offically in paint prison . He quoted me a super price to replace the rocker , so i'm gonna let them do the metal work . I disassembled the truck and did 2 weeks of prep and block sanding . I also bought a used hood for it off of Craigslist . I'm still doing the Z-28 scoop on the other hood and having it painted . The interior will also be repainted factory blue with GM pure white base coat / clear coat . The core support and frame will be semi gloss black and the bumper , grill and headlight trim will match the wheels . The side mirrors will be painted body color with black mirror heads . It is supposed to be out friday the 29th so it'll be on the trailer for the Houston meet if they meet there own deadline . I'll try and get pictures of it in the various stages of paint .
