how to tell a th350 from a th400
I was just woundering if someone could tell me how to tell a turbo350 from a turbo400 trans. My trucks trans is option coded as a M49, what trans is that?
Re: how to tell a th350 from a th400
Looking at the shape of the pan is the easiet way.
400 oil pan is shaped like Texas.
quick and easy;
kick down cable = TH350 No kickdown cable = TH400 |
nother quick way,
th400-6 bolts in the tail housing th350-4 bolts |
The top right transmission in the picture is a turbo 400 transmission. I look to see where the modulator valve is. It should be on the passenger side closer to the front when looking at the transmission from the back.
TH350 vacuum modulator faces right
TH400 Vacuum modulator faces back |
Boy look at all those ways to tell the difference
2 Attachment(s)
Just like everyone else said:
TH350 has a Mechanical (cable) Detent Cable. TH400 has an Electrical Detent Switch. Easiest way is the shape of the drainpan. |
Thanks for this thread. I now know I have a 350.
Cool to know that people still read threads that are 2 years old.
no 4 years old. I just found out i have a th400 Thanks.
mmmm thread necro |
Thanks for the thread, now I know I have a 350 TH.
Is there a preference 350 vs 400? Thanks again |
Anyone have a good recommendation of a deeper sump aluminum pan with a drain plug like the one pictured above?
http://mag-hytec.com/store/index.php...products_id=97 Posted via Mobile Device |
Here is what I used on MY T350
http://www.jegs.com/i/Hughes+Perform...FQzNnAodpGwAaQ |
I know this is a really old thread ,but it is still VERY useful to us that are not quite up to the level of some of you other guys . I figured out i have a TH350 thanks to this thread without breaking any kind of sweat. thank you everyone for sharing your knowledge. :chevy:
But the SPID was telling the truth... :lol:
Gary |
Right on fellas, and thanks blukangoo for the unmistakable picture of the two different pans.
Yea, this thread is old as crap, but it's the first Google search result that appears when you do "how to tell th350 from th400" and it was worth my efforts to log into the site and surf around like old times. I got a camaro last month and was wondering if it had a th350 or th400. Figures the best truck forum out there had the answer to my question. Upon deep investigation, if I had only waited 7 more days I could have made this a 9 year spread from initial post to my reply. Oh well, guess nobody can be that awesome. |
another quick and easy......governor gear has a 4 bolt cover on a T400, a clip bail cover on a T350
2 Attachment(s)
Unless I'm looking at it wrong, my 350 modulator faces BACK?? |
It doesn’t.
He was wrong. Turbo 350 faces back. Yours does. |
