Big 13" Front and rear Disk brake kits!!
We now have the big 13" Disk brake conversion kits availible. Both front and rear. The front kit includes: 2 1/2" drop spindles, 13" GM rotors, Hubs, bearings, seals, hoses and massive GM calipers. The kit is availible for the front for years 63-70, 71-72, 73-87. The rotors are both solid and cross drilled and are 5 on 5 lug pattern. No 6 lug yet. ($799.95 for solid rotors and $849.95 for cross drilled rotors)
The rear kit includes: GM Rotors (both solid and cross drilled), calipers with E-brake hardware, mounting brackets with hardware, hoses, Banjo Bolts, and Copper washers. The rotors are both solid and cross drilled and are 5 on 5 lug pattern. No 6 lug yet. ($749.95 for solid rotors and $799.95 for cross drilled rotors. We will be trying to get these uploaded into our site this weak some time. If you like untill then, you can call us toll free 888-338-2502 (in the USA) 360-570-1860 for out of country calls. To place an order with us. WES |
Re: Big 13" Front and rear Disk brake kits!!
These kits also require that you have at least 17" wheels. WES
:clap: Are these 2 piston front and rear?
Yes they are the 2 piston Calipers. WES
when you say solid, do you mean smooth? The rotors are vented?
ttt
Any pics of the kits Wes???
2 Attachment(s)
Also I was informed this morning that the 5 on 5 rear kits won't be ready until next weak. However the 5 on 4 3/4 rear kits are availible now. All front brake kits are availible now. (Just to avoid confusion) WES |
Fronts would more than likely be two and the rear one?
Are the rears rotors 13" as well?
Thanks |
They are Duel Piston GM Callipers, and both front and rear rotors are 13". WES
What axle does the rear fit? 10 and 12 bolt or ?
"We now have the big 13" Disk brake conversion kits availible. Both front and rear. The front kit includes: 2 1/2" drop spindles, 13" GM rotors, Hubs, bearings, seals, hoses and massive GM calipers. The kit is availible for the front for years 63-70, 71-72, 73-87. The rotors are both solid and cross drilled and are 5 on 5 lug pattern. No 6 lug yet. ($799.95 for solid rotors and $849.95 for cross drilled rotors)"
SO is that the price of the kit or just the rotors? |
[QUOTE=pcmcobra;2608054
SO is that the price of the kit or just the rotors?[/QUOTE] that would be for the kit;) |
To the top. WES
back to the top... WES
no slotted and drilled rotors available?
Sorry not at this time. WES
We are developing new 5 on 5 axles for the guys with the 63-69 12 bolt rear ends to make it easier to convert to 5 lug systems. The reason that we didn't include 1970 in the mix is because the axle length is the same for the 70 as 71 and newer, so stock axles are direct replacements. WES |
Hey Wes,
Great looking kit. Are the rotors truly drilled, or dimpled? In the past I have bought drilled rotors, and have had cracking problems. I have since changed over to slotted and dimpled style rotors which look the same, but maintain structural integrity. Just asking as many manufacturers are actually calling the rotors drilled when in fact they are dimpled. Shawn |
They are drilled but they are drilled on C&C machines at the manufacture. (Not over seas like some) We do have the solid rotors availible also though. WES
Back to the top...
Sunday bump...WES
What is the delivery time once ordered??
