project nightmare
here is my 1967 GMC i just started work on .its been a nightmare from the start,every time i start working on it the weather gets bad.i had it running,but now i have nothing.wont start....any advice?well without ferther delay here are the pocs of project nightmare
http://i229.photobucket.com/albums/e...Picture269.jpg http://i229.photobucket.com/albums/e...Picture270.jpg http://i229.photobucket.com/albums/e...Picture263.jpg http://i229.photobucket.com/albums/e...Picture264.jpg here are pics of the rigged sunroof[not my doings] http://i229.photobucket.com/albums/e...Picture265.jpg http://i229.photobucket.com/albums/e...Picture266.jpg http://i229.photobucket.com/albums/e...Picture267.jpg |
Re: project nightmare
more pics
http://i229.photobucket.com/albums/e...Picture008.jpg motor is a olds 350 http://i229.photobucket.com/albums/e...Picture010.jpg http://i229.photobucket.com/albums/e...Picture011.jpg http://i229.photobucket.com/albums/e...Picture012.jpg http://i229.photobucket.com/albums/e...Picture016.jpg http://i229.photobucket.com/albums/e...Picture017.jpg http://i229.photobucket.com/albums/e...Picture021.jpg here is the vin number,can anyone tell me about this truck http://i229.photobucket.com/albums/e...Picture023.jpg http://i229.photobucket.com/albums/e...Picture024.jpg http://i229.photobucket.com/albums/e...Picture025.jpg |
wow... looks like you have alot of work ahead of you. good luck piecing that one back together.
Wow, looks like the '80's grabbed ahold of that thing and won't let go. As far as starting goes, start with basics: Air, Fuel, Compresion. Obviously, your getting air. I would check for spark first. With an HEI, the ignition modules are known to go south. I'd almost be willing to bet that's what it is. How long has it sat?
It's cool to see a Rocket in there. Those are real good motors. Had a couple myself. Torque MONSTERS! |
I decipher your Vin as the following
C=2wd S = inline 6 cylinder 1= 1/2 ton 57 = 115' wheelbase (shortbed) 0D = 67-69 fleetside good luck with your build. |
After looking over your pics again, I seen the pic of your fuse box. All that needs to be sorted out. One thing to keep in mind with automotive wiring is grounds, grounds, and grounds. And then go back and check your grounds. A little off the subject, but I once had a 2004 Frieghtliner in because it was completely dead. No nothing. Turned out to be a bad fog light switch that was grounding out. No kidding. Good luck with your project. I'll be watching.
Good luck with the build!
get to work
going to the junk yard this weekend to look for parts.wish me luck
started back on the truck today,found a newer driver side door for the truck .got it on the truck but it not wanting to line up.will post pics 2morrow.yall will like the paint jod the door has.also going to order a ez wiring get this week.
