P/S idler arm swap?
I have a 66 short step I swapped the front cross member on from an 81 half ton. I need to find an idler arm that will work with the 81 center/drag link. What have you guys used? I did a search and came up empty. TIA!
Re: P/S idler arm swap?
I used the later model idler arm too. Just clamp it into place and drill the two holes.
So just eyeballing it get's it close enough??
I've done two trucks that way without any problems. Just square it forward to back and level the center link in relation to the crossmember. Use C clamps to secure it to the frame and drill the two holes.
Just use your original idler and drag link as a reference. Take some measurements and position the newer one in the same position and then do as Tx Firefighter said, clamp it to the frame and drill your holes.
I just swapped a 71 crossmember and spindles under my 64, using all 71 tie rods and components including the 71 idler arm. And it is just like the boys have said before me , measure, clamp and drill away.
OK, thanks for the tips.
I noticed that if you bolt up the steering box first it give you the right angle on the idler arm. Before I knew about the REZ kit I just drilled some holes and bolted up the steering box with some spacers. After I used the rez kit I had to redrill my idler arm again as it angled back about 1/2". I welded a piece of 1/8" metal to the back of the first hole I drilled and filled the hole back up and then drilled a new hole. can't have oblong holes holding the idler arm.
