2004 yukon xl tranny slipping
Hi I'm new to this board. I have an '04 yukon xl 5.3 all time 4 wheel drive no 4 wheel steer. it has 149,000 miles on it and has run great since i bought it about 3 years ago with around 100,000 miles on the odometer. Changed the tranny fluid and filter about 4 months ago. Had no problems then just unsure when it was done last. Suddenly and I mean without any warning or prior slipping 3rd and 4th gear are slipping like crazy. 1,2 and reverse work great but as soon as tranny shifts to third tach races to 4,000 rpm and you can barely keep 55 mph. My question is does a clutch pack go out like that or is the suddenness more indicative of a solenoid or electric sensor issue. I do my own wrenching on my motorcycles and my alfa spider but they are manual trannys not automatics. Also I have had no dash board warning lights I have no obd tester to pull codes myself so was hoping for some info to arm myself with when checking with the dealer or local tranny shops. Any help would be greatly appreciated.
Paul |
Re: 2004 yukon xl tranny slipping
I cant remember I think it was mobil 1 I know I checked at the time to make sure it was compatable with my year. I use mobil one oils in my other trucks( ford explorer), but have to use high zddp oil and stp red in my alfa due to the flat tappet cams. I have no leaks and i checked several times after to ensure the level was ok. The fluid now seems darker but still red not black. If it were to be clutch packs is it more reasonable to put in a rebuilt tranny and torque converter or just replace the clutch pack. My instinct is all the other parts are old and if the tranny comes out I should replace all I can. In my research I saw where some companies add extra clutch plates to the 3-4 pack is this needed for a stock motor that does moderate towing occaisionaly? This is the first transmission issue I have had with my chevys my 98 5.7 pick up never gave me any tranny probs until it was sold with 135,000 miles on it so I am somewhat cluless in this particular area. Thank you for responding so quickly.
Paul |
Example, i can run a compatible trans fluid in hondas but they shift like crap. You put the factory Honda fluid in and it shifts right.... just some thought. |
Sounds good Now I just have to determine what it is going to cost to fix. My alfa is very tempermental on the type of gear oil and engine oil needed so I am familiar with the subtlety. I just was not aware for my yukon that I needed to use anythingelse other than making sure the brand I chose said it was for that year model gm. Live and learn. Do the clutch packs, solenoids, bands etc. come as part of a rebuilt tranny as a unit? It seems if there is no specific electronic component or solenoid that affects 3rd and 4th gear I'm looking at putting a rebuilt transmission in. Since it shifts into 3rd and then slips I am assuming it is likely clutch pack unless someone can advise me otherwise.
Also depends on your budget... If it slips in those gears, slap a clutch pack in it and drive it.. But that just seems shady ya know... Good luck. |
If it happened all the sudden its probably a apply curcuit problem(cracked servo piston, busted separator plate, bad lip seals on the apply piston, ETC...) So i whould get it rebuilt because just putting clutches in it will not solve the apply curcuit problems. |
Hey cline, do you guys have a tranny dyno there??? Whats your average rebuild cost on his transmission?? |
$1200 to $1500 with R&R. $800 to $1000 bench job. |
Thanks guys you have confirmed what I was thinking, there is just no sense in not putting a rebuilt in as long as the old one has to come out. I am going to make sure I have an up graded 3-4 pack do i need to ask for a 4l65e
to get the upgrade or are the rebuilt "4l60E's" already there. I know the 65's did not have 8 or 9 plates in 3-4 but had more than the 60's. I also thought the 65 had different planetery set. I am going to present these questions to my mechanic so I can ensure I get the best tranny to put in. I do appreciate the input and will post back when the repairs are done. Paul |
Thank you I had takren it in yesterday at lunch and there were no dtc codes it showed it to be shifting into third and then it just slips bad he told me it would nee dto be pulled so I told him to get me prices on a gm rebuild that has 100,000 mile /3yr warranty v. his supplier of rebuilts with a 90 day warranty and based on cost we will proceed accordingly. Thanks to all who responded.
paul |
just nmake sure they use dexron 6 in the new unit
You can run dexron III fluid in any and all 4L60E/65E transmissions with no problem.
I just got done putting a Jaspers in my 2000. I am running BG syn in my truck
Well I'm being told it will be $3500 parts and labor for a gm from the dealer rebuilt 4l60e installed labor included(about $700) this is with 3 yr 100,000 mile warranty or he can get me a localy rebuilt 90 day warranty tranny for 2400 plus labor or a junkyard pull " low milage non rebuilt" for 2200 both plus labor to install. I do not have that much at this moment so it will wait for a liitle but wanted to pass on the prices I was given. Unfortunately I live out in the country so my options are limited.
Paul |
Order a rebuild online and then install it yourself. Save you quite a bit of money... Do me a favor, get me the year, make, model and vin if you feel safe. I can tell you exactly what fluid you want. |
Paul |
GM recommends Dexron III to 06. PM me if you want to and ill recommend some shops, 90 day warrenty is a joke.
unless you can find someone who has the special tools to loan you that you need to rebuild it, let someone else rebuild it for you. If you have to buy the special tools to do it yourself it would probably end up costing you more in the long run. trany special tools arent cheap. And as far as tranny fluid you can use dex 6 on nething that used to call for dex 3 EXCEPT transfer cases. (one of the additives in the dex6 will deteriate the nylon parts inside.) However you CANNOT use dex3 in nething that calls for dex6. Besides dex6 is a better trans fluid than the 3 neway. Has better friction modifiers and resists breakdown to higher temperatures. And really whats say $20 more spent on fluid compared to the $3000 spent on replacing a burnt up tranny?
His 3-4 clutch failure is not fluid related. Low fluid level maybe but not the type If the transmission gets hot enough to break down dexron III its toast anyway I dont care what fluids in it. |
