Will 73+ lower a arm u bolts fit 72 front end?
I know I keep asking Q's about the 73 up stuff but the parts houses around here carry alot of that year stuff and I don't trust thier books! Thanks.
------------------ "KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window |
I put '77 front end pieces, including lower control arms, on my '67. Had to buy new U-bolts (from my local Chevy dealer) and drill the existing holes up to 9/16". They went right in.
Rick ------------------ Absecon, NJ 1972 Triumph TR6 - full resto finally done! 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, headers, Flowmasters, Edelbrock, 600 Holley, 3/4 drop - in a million pieces See some pieces at: www.freephoto-i.net username nosto53 |
Oops, sorry; didn't read the topic correctly! My new answer is 'I don't know'.
Rick |
73-87 arms will bolt to your engine cradle, yes, they use the rubber style bushings instead of the big metal solid style bushings like on all 3/4 and 1 ton trucks of all years
happy swapping ! http://67-72chevytrucks.com/board/ubbhtml/smile.gif |
Maybe I'm being dense but does this mean the U bolts will work? 30 hours OT has fried my brain this week! :P***
I used a '81 donor truck for my swap and the u-bolts would NOT work. I used the old ones, rather than drill out the crossmember. You could go either way. Good luck!
Brian ------------------ '68 Shortbox Stepside -- 250 cu.in. 4 speed, disc swap up front '00 Grand Prix GTP Sedan I AM CANADIAN!!! Go Oilers! |
Thanks, I sure don't mind drilling the holes out, especially if it means a larger bolt. Anyone know if these are a higher grade bolt are just your typical hardware store variety?
70Jimmy,i think those U bolts will be a dealer item,& a high grade fastener. if your old ones are in good shape,I would use them..........69 longhorn.
I would use them but I lost 2 of them!
i have one and can find other., oh wait, i have a whole front end, how many do you want ? i have to disassemble the front so i can hide the parts in attic because of the damn city code warning i got today
interested ? i dotn need em was gonna scrap em or something anyways they are 3/4 ton ones, IE the larger ones like you say these are not a hardware store item lol ! these are hardened steel and special shape and diameter, so... i owudnt be putting inferior bolts on somethig so important ! if they break then there goes your front end down to the pavement!! [This message has been edited by Fast68Chevy (edited March 09, 2002).] |
