71 Blazer "Finishing Touches"
I named this blazer "Finishing Touches" because the majority of the hard work has been finished. I found this on my local Craigslist. Went because it was a good price and my original plan was to use the tub and convert it to 2wd. However, after seeing the truck in person and realizing it was almost finished, I decided to buy it and finish it up. Going to hopefully get it done soon and enjoy it this summer. Then, we'll see if I get any offers to sell it so I can get some funds back to get back on my 67 Resto-mod pickup.
First of all, I'd like to thank the PO (Previous Owner) Normally most people come on here complaining about PO's. This Blazer, however, was built right. I really didn't look it over as well as I should because I was afraid of missing out on the deal. Kept thinking someone else would show up with cash and steal it from me. :lol: As I've started working on it I keep finding nice detailing and quality parts. For example, a complete ARP stud kit for the engine. rustproofed and painted inside the cowl vent area and the vent covers were taken apart, new seals installed, and re-riveted. Powdercoated door striker plates, under dash courtesy lights and glovebox light added, firewall insulation and factory style cardboard cover installed, wiring neatly installed and wrapped with loom to protect it. Frame was sandblasted and sprayed with POR15, suspension was detailed and all new suspension components. Transfer case with new seals and painted, transmission had a $800 rebuild and was painted, motor had 1700 invested in it and painted/detailed, new heater core and blower motor and detailed boxes inside and out. All new body bushings,bolts/hoses/belts. New brake assembly, new power steering gearbox, pump and hoses, etc.etc.etc. I just got through tearing down a truck and starting a frame off, detailing a frame and installing all new suspension so I can appreciate all the hard work that went into this. There are a few things I will fix that he didn't do to my satisfaction. The front rotors are questionable while the rest of the brakes are all new...those will be replaced. He put new hood hinges on that aren't fitting well so I'm taking my nicest set of used ones and will be switching them out. There are four spots on the body that need addressing. (that's right only four! :metal: ) They were repairs done by the previous owner with metal patches but not up to the quality of the rest of the blazer. These will be removed and new metal welded in. Hardly any more dings on the entire body other than right at the taillights that will be easy enough to get to. So some light metal work, body work, paint, and then final assembly is all that's left. Here are the pictures I took the day I went to look at it. http://i562.photobucket.com/albums/s.../blazer002.jpg http://i562.photobucket.com/albums/s.../blazer029.jpg http://i562.photobucket.com/albums/s.../blazer001.jpg http://i562.photobucket.com/albums/s.../blazer016.jpg http://i562.photobucket.com/albums/s.../blazer017.jpg http://i562.photobucket.com/albums/s.../blazer015.jpg http://i562.photobucket.com/albums/s.../blazer010.jpg |
Re: 71 Blazer "Finishing Touches"
The underside is as nice as the top...
http://i562.photobucket.com/albums/s.../blazer020.jpg http://i562.photobucket.com/albums/s.../blazer009.jpg http://i562.photobucket.com/albums/s.../blazer008.jpg http://i562.photobucket.com/albums/s.../blazer007.jpg http://i562.photobucket.com/albums/s.../blazer003.jpg http://i562.photobucket.com/albums/s.../blazer004.jpg http://i562.photobucket.com/albums/s.../blazer006.jpg http://i562.photobucket.com/albums/s.../blazer019.jpg |
Here's the areas I need to work on...started taking them down to bare metal...only one area he had bondo and just for dents...no rust inside or out...
http://i562.photobucket.com/albums/s...odywork004.jpg http://i562.photobucket.com/albums/s...odywork003.jpg http://i562.photobucket.com/albums/s...odywork002.jpg http://i562.photobucket.com/albums/s...odywork001.jpg Here's the original gate that needs a little work on one spot on the inside but no dents. I'm going to use the shaved repop for my other project's planned custom tailgate... http://i562.photobucket.com/albums/s...4th2010001.jpg http://i562.photobucket.com/albums/s...4th2010002.jpg |
that twin shock would scare the crap out of me. begging for failure.
looks like he was on the home stretch, why did the guy bail? |
I'm definitely not a 4WD suspension guy so I'll look into other options for the dual shock... |
Here's some of the other detail shots I took of it.
http://i562.photobucket.com/albums/s...4th2010005.jpg http://i562.photobucket.com/albums/s...4th2010004.jpg http://i562.photobucket.com/albums/s...4th2010006.jpg http://i562.photobucket.com/albums/s...4th2010007.jpg http://i562.photobucket.com/albums/s...4th2010011.jpg http://i562.photobucket.com/albums/s...4th2010013.jpg http://i562.photobucket.com/albums/s...4th2010016.jpg |
looks nice and clean, good snag!
wow, that is clean. looks like a very easy project that will bring in some big bucks once it is all done.
good score dude |
What can you tell me about that heater defrost hose mine need to be replaced agian and the aftermarket one I bought last time really suck... Very nice score on your part I wish my blazer was that far along..
Subscribed
Damn nice score looks like he got most of everything done on it and did a decent job of it. Looks super clean from here. Can't wait to see it when you get it all done man!
Thanks everyone. I know I scored on this one. It is as clean as it looks in the pictures. Charlie can attest to that. A little sanding, some weatherstrip (have almost all of it already) a finished interior, and it's cruising time :chevy:
He did most of the suspension work in 2006 and the engine/tranny late last year and I think the body work did him in with lining everything up. |
wow gonna be sweet! Wheres the top?? I like that color is it factory?
just need to put that second shock in double shear somehow.
looks like the po was definitely trying to do things right, nice score |
Yea guys this is a real score for Jonathan. If I were to guess, I would estimate that Jon paid about 35cents on the dollar for this truck.
I don't understand why the po would get so close to complete, only to bail. If I would have seen the ad first, this would be my thread. :lol: I'll say it again. Great buy. I also think that when completed, it will be hard for you to want to sell. |
That is a great looking project..another guy that went into the statistics of restoring project that did not get finished category...Glad to see you have it and knowing that it will be finished....
Yea but money comes and go's. A blazer in that shape for the $ you spend would be hard to duplicate.
yeah, it'll have to be a REALLY good offer that will let me afford to do my truck the way I want it AND have another "toy" for me to sell it.
Honestly though, I enjoy learning about the truck, planning out a gameplan, and working on the truck more than I enjoy sitting at a show all day showing it off...I think I'd be happier constantly working on projects, completing them, and selling them than having one sitting in my garage.... ...look at your blazer...it was a show truck and you still tore into it to make it better. It's just fun wrenching on these things :chevy: |
Yea the tinker around part is the fun part. What I do not like is calling, driving taking all the time invoved only to find junk. I'm just sayin:lol:
Jason at Pop's Chop Shop started on the little bit of metal work left...tackled the worst area first....the offending area....
http://i562.photobucket.com/albums/s...ustrepair1.jpg The backside....see how the PO drilled holes to pull a dent out.... http://i562.photobucket.com/albums/s...ustrepair2.jpg And the new sheetmetal formed and welded in :metal: http://i562.photobucket.com/albums/s...ustrepair3.jpg |
'bout time!
Subscribed... |
I'll be working on it every night this coming week other than Wed night (prayer meeting and Bible Study) I really want to knock this thing out and start driving it.
