49 Chevy 1/2 Ton Steering box question
4 Attachment(s)
Working on rebuilding the steering box on my 49. Not sure how to get the bottom bearing race and keeper off. Any one have any ideas? The keeper doesn't seem to have a way to remove it.
Thanks |
Re: 49 Chevy 1/2 Ton Steering box question
Any chance you have to pull the whole column so it disassembles and slides off the other end? Or it might just be a pressed sacrifical fit? Just a thought....I've never had one apart.
Does this help?
http://chevy.oldcarmanualproject.com...51ctsm0906.htm |
I bought the repair kit and it had the same pages included. What I can't figure out is how to get the end bearing off.
Shaft is disassembled, but the bearing won't come off over the worm gear. Only other way is to some how remove the conical shaped retainer on the bottom of the shaft. That is what I can't figure out. |
Edited by Moderator
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. |
According to the manual for overhauling steering gears you twist off the collar. But you need a replacement. Is there one in the kit?
http://chevy.oldcarmanualproject.com...20mtsindex.htm http://chevy.oldcarmanualproject.com.../5220mts11.htm |
