Please Take a Look
I would love to know how to make one of these. This one was on ebay.
Maybe some pics of the under side. What they did to the T-case and stuff I know fwd only and if you guys and gals thing it would last. Thanks http://a6.sphotos.ak.fbcdn.net/hphot..._7650860_n.jpg http://a1.sphotos.ak.fbcdn.net/hphot...91_52783_n.jpg http://a5.sphotos.ak.fbcdn.net/hphot..._7799340_n.jpg |
Re: Please Take a Look
There was a guy on ebay selling 88-96 version of a truck like that..that one is sweet
I always wondered about these trucks as well. There used to be one around here. I guess t-case in 4 wheel high and its front wheel drive.
Ya i wondered if it puts a ton of stress on the front drive line.
I would use a 3/4 or 1 ton. |
Thats cool. It looks like a car trailer welded to a truck? That sure seems like it would be taxing on it if it's running on a front drive line.
In regards to the trans. you simply pull the rear tranny shaft out and make a press fit cap that replaces the rear oil seal.
While I also think the truck is interesting, the concept just doesn't seem to be cost effective and is wrought with issues:
Just seems like a whole can of worms.A stock truck and fifth wheel trailer set-up would be cheaper and much more manueverable. And it doesn't have any of the above issues. Additionally you still have a regular truck that is marketable to the masses. Here is another concern: http://www.pirate4x4.com/forum/showthread.php?t=859251 I can't speak for other states, but in Kalifornia, you will have to pull through the scales and will be subject to DOT inspections. |
The only way I would do that is if I had a pickup that the rear half was written off, otherwise a seperate trailer is more practical. However if I did it I would raise the bed and put tandem drive axles in the rear.
they should have found some rims like the front of the truck has and put them on the back end x4
hmm wonder how that handles.
ya that doesnt seem good for tunrs.....
Those front tires look a little skimpy to be pulling all that weight around. |
same wheelbase as tractor trailer? they seem to be able to manuver around when bob tailin'.guess you'd take it to the same shop for repair?
dont know just asking. |
