88-98 FAQ's "Is your truck running weird? Check here it could help"
Post your threads here for the new 88-98 FAQ post which will be a separate sticky when complete.
Please make sure that the pics are uploaded to this sites gallery when used here to ensure the URLs are still there later for when we are looking through this thread for help, Thanks. |
Re: 88-98 FAQ's
Ill add more when i find some good ones to help
High idle problems http://67-72chevytrucks.com/vboard/s...d.php?t=439984 EGR identification (thanks Chevytech) http://shbox.com/1/EGR_ID.jpg |
Re: 88-98 FAQ's
Scott – dig through these and see which ones you want.
I will work on this more later. Running Rich, or acts like no choke = Coolant sensor testing: http://67-72chevytrucks.com/vboard/s...d.php?t=322811 http://67-72chevytrucks.com/vboard/s...d.php?t=379142 *************************************** Tighten up Tilt column links; On C/K trucks in 1995 they went to a “new” style column. If your truck is a 1994 or older the following information should help. Here are some steering column sites with photos that tell how to repair loose tilt columns. The photos should be helpful. http://www.fieros.de/en/articles/steering.html http://elcaminocentral.com/article95.html Looks like on this site he did the quick fix and did not take it apart far enough to tighten all four fasteners. http://www.chevyasylum.com/column/tiltcol.html Exploded View of a tilt column. http://www.nastyz28.com/tech/e-tiltcol.html Older car but good photos http://buickperformance.com/tiltstee...lumnwobble.htm *********************************** Tilt column lock plate removal; http://67-72chevytrucks.com/vboard/s...ht=tilt+column ***************** Fuel pressure testing – split hose in tank: http://67-72chevytrucks.com/vboard/s...d.php?t=375132 ************************** Set timing wire connector for 1988- 1993 C/K pickup trucks illustration: http://67-72chevytrucks.com/vboard/a...1&d=1251120221 |
Re: 88-98 FAQ's
This is gonna be a great help to those who seek help, without asking "where, who, etc.," before doing a search for the help they need. There's a lot of information on here that people can access, if they will just take the time to utilize the already available resources.
Re: 88-98 FAQ's
Re: 88-98 FAQ's
Cleaning evap core for better a/c function
Edit: Also wanted to say that an 88-98 FAQ section is a terrific idea -- it seems like every day there's somebody with EGR/IAC/ECTsensor problems. The FAQ section should be subtitled "Is your truck running weird? Check here first!" |
Re: 88-98 FAQ's
1991 & later TBI V8 Oil pressure sending unit location, engine wiring & sensors illustration:
Also shows ground on back of passenger cylinder head. http://autorepair.about.com/library/...bl283a-lib.htm TBI V8 Knock sensor location photo from “PCMCOBRA”, from one of the truck boards. http://i114.photobucket.com/albums/n...010Small-1.jpg Dash Brake indicator on or blinking = RWAL problems Here are two of the better threads http://67-72chevytrucks.com/vboard/s...d.php?t=302690 http://67-72chevytrucks.com/vboard/s...d.php?t=399153 TBI parts & sensor photos EGR (Exhaust Gas Recirculation) valve EGR solenoid IAC (Idle Air Control) MAP (Manifold Absolute Pressure) sensor TPS (Throttle Position Sensor) All labeled in photo of 1993 Silverado: http://67-72chevytrucks.com/vboard/a...1&d=1278787232 |
Re: 88-98 FAQ's
HOW TO: Manual locks and windows to power conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=445732 |
Re: 88-98 FAQ's
