72 blazer stuff
5 Attachment(s)
$100 summit 20 circuit wiring harness: I dont have the box but everything that came with it is either spliced in or in a bag. SOLD
$150 Single wall hard top: Top is in driver condition, has a crack next to the handle with one small hole you can see in picture. SOLD $200 (4) Stock 6 lug 15in wheels with center caps and outer chrome rings. GONE TO SCRAP $100 Holley 650 CFM Carb with manuel choke and upgraged 50cc acel pump with rebuild kit |
Re: 72 blazer stuff
5 Attachment(s)
few more pics
Re: 72 blazer stuff
last is the carb, I am willing to ship all of it, would prefer local pickup for the hard top but if you set up shipping for it I will get where it needs to be to get shipped.
Re: 72 blazer stuff
Do you have the key to the hatch? Interested in the top only, would be able to pick it up.
Re: 72 blazer stuff
Interested in hatch if it gets to me.
Re: 72 blazer stuff
No key came with it for the hatch when I got the truck. |
Re: 72 blazer stuff
Re: 72 blazer stuff
Can you get a couple more pics of the top, mainly front lip and inside mounting rails.
Re: 72 blazer stuff
I will try to get some pics this weekend and get them posted by monday at the latest.
Re: 72 blazer stuff
do you know if those are the original rims?
Re: 72 blazer stuff
to my knowledge yes they are original.
Re: 72 blazer stuff
I'm interested in the harness. Are the wires indivually labeled? I have this color blind thing. Thanks
John |
Re: 72 blazer stuff
yes all the wires are labeled. I do have the directions that came with them its just got a little moist in the garage but still very readable
Re: 72 blazer stuff
Any luck with the pictures of the top?
Re: 72 blazer stuff
Is this set up designed for GM columns?
Re: 72 blazer stuff
Sorry still tryin to catch up from the long weekend, I will get the pictures taken in the morning and post them when I get to work at night.
Re: 72 blazer stuff
If you are talking about column ignition then no.
Re: 72 blazer stuff
I was looking at the summit racing add for this harness set. They offer the kit with or without the GM column connector. If you look at any gm column, there is a connector at the bottom of the column. It has many wires in the connector which works signals horn etc. Its not for the ignition switch. Your directions should specify what it is that you have. Thanks
John |
Re: 72 blazer stuff
can you tell me how wide they are?
Re: 72 blazer stuff
Just sent you a pm on the carb.
Re: 72 blazer stuff
it is the one with the column connector, however the connector that comes with the kit is flat and on my blazer its curved.
scott Quote:
Re: 72 blazer stuff
PM sent
Re: 72 blazer stuff
I will measure them when I get off in the morning.
Re: 72 blazer stuff
Sorry for the delay my camera has been misplaced I should have the pics taken and up before the weekend.
Re: 72 blazer stuff
If you could, I'd like to see more pics of the carb, too. It isn't a spreadbore, is it?
