88-98 Chevy & GMC Heavy Duty Headlight Harness
1988 - 1998 Chevy and GMC Heavy Duty Headlight Harness. What the harness does is this; The way all 1988 - 1998 GM trucks headlights are designed is to draw power for your headlights from the headlight switch in the dash using small 16 - 18 Gauge wire for power. Which results in a lot of lost voltage, and also the danger of melting wires or your headlight switch with upgraded headlights such as HID's. Now what the HD Harness does is this:, by using 3 relays (1 for the high beam, 1 for the low beams, and 1 for the 4-High feature) it draws power directly from the battery and uses 14 Gauge wire to power the headlights from the relay and gives your headlights 13.8 volts +. Which will result in having brighter, and safer headlights! The harness' are 100% "plug n' play", there is no cutting of the original factory wiring what-so-ever. Also, if you have HID's and have issues with "flickering" this will clear up that issue. These harness' also have 4-High relay built in, so the low beams stay on with the high beams, which also increases your night time visibility! These are not a low end cheap harness like the so called "Relay Harness'" that various Internet retailers sell. These are complete NEW high quality true Heavy Duty Headlight Harness', that replaces your factory Headlight harness (but the factory headlight harness can remain on the vehicle). ALL of the connections are cleanly soldered and heat shrunk to provide the best connection possible. The HD Harness comes with complete directions on how to install the HD Harness kit. If you have any questions feel free to contact us! The Harness' are $95.99 shipped to anywhere in the lower 48 states. Payment: PayPal or Postal Money order Condition: NEW http://i1203.photobucket.com/albums/...ghtHarness.jpg MADE IN THE USA |
Re: 88-98 Chevy & GMC Heavy Duty Headlight Harness
I have one of these harness that I purchased through another forum. It has been doing great and trouble free for over two months I believe. Install was super easy also.
Just a free bump and a great guy to purchase from. The harness is built really well and has much better quality than others I have seen. Plus its "Made in USA!" |
So if I bought one of these from you would I still need the harness that makes my low beams stay on with the high beams?
No sir, these HD Headlight harness's come with the 4-High feature (low beams stay on with high beams) built in. So the harness is 100% Plug n Play! |
Do you have a harness that will work on a 2005 GMC Jimmy? I'm ready to order from you so let me know asap.
Any Black Friday sale's on these? :)
Thanks Baron, I received my harness the other day and it looks great, very professional. I will be installing it in the New Year.
Bump! Happy Holidays guys!
sent a pm.
First one for the new year Nick |
Pm Replied Nick! Happy New Year! :chevy: |
any way to add in foglights like the tahoe limited harness's?? might be interested in one if you can do that
Thanks! |
I am interested in this but am deployed right now so I don't have much time on the Internet. Can you email me at @comcast.net?
Posted via Mobile Device |
:flagw: |
I noticed in the picture the connectors seem to be for the composite headlights. Do you have a harness that works with the quad headlights?
Do you have a price for it off the top of your head?
