87 Chevy 4x4 5 speed conversion
hello i have been looking all around the internet for anything on 4x4 5 speed conversions and found nothing. So i am doing it anyway and i figured i would make a build thread to show it along the way.Attachment 821559Thats my baby and my 700r4 took a **** so out it came and in goes a nv4500! it is also getting 3/4 ton axles with 4.10 gears it has 35's and 5 inches of lift and planning on going 9.:chevy:
Re: 87 Chevy 4x4 5 speed conversion
Nice truck. Thats about how I want the one I'm doing to set when I'm done. In the 4x4 section DirtyLarry put a NV4500 in his. Search it out.
You will find that it is a matter of removing bolts and installing bolts. I did the swap on my truck a couple years ago and love it. I went from an SM465 to NV4500 so I already had the clutch pedal, but it is a very easy swap.
You will need a different transfer case, or at least change the input splines if your going to use your current tcase. The manual/ turbo 400 have a different spline count than the 700r4. |
I have an 85c20 350 its auto and i want manual since uve used both the sm465 and the nv4500 what do u recomend. I know nothing on the 465 someone posted something i saw eArlier saying it was soundin better and im short on time and can not research it. Also how many speeds is it
Posted via Mobile Device |
