69 C10 Window Track Issues
Ive got a 69 c10...i am replacing all the window tracks in both doors, but i am having trouble finding the correct track strips and weather stripping that slides into the inner door division bar and side track. i can find all other weather stripping but those. if anyone can give me some help it would be greatly appreciated. i need to get my windows back in and i dont want them slamming around internally not being in the track slot rubber/felt strips
Re: 69 C10 Window Track Issues
are you talking about the felt strip that goes on the vent window side
http://www.classicparts.com/Door/products/252/3/0 classic parts has all the door weather strip peices |
yes the lower part of division bar and the other side window channel. the one that are inside the door themselves. all my tracks were rusted out so i had to get all new ones. but now there is no rubber/felt insert in the lower halves when the windows gets rolled down. its just bare metal. my old tracks had the rubber/felt in them but are to badly damaged to be used again
Welcome from Central Florida....you know what makes this site so great?
Stuff like this... Here you go. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=17 |
Reno & 454
thank you so much both of these websites are exactly what ive been looking for. and reno you are correct, it is so very nice to have dedicated sites like this for help all around the country. thank you both for all your help, and very quick responses. |
You are very welcome....I think you owe us a pic of your truck.
Ok, will do...pictures to come
glad to help and yes we are a picture happy forum lol
Reno,
which weatherstripping goes into number 12. that is the piece im trying to find but havnt with any luck. #12 is the window track on the latch side of door. my stripping is so brittle and destroyed my windows rattle around. if you have any other info it would be greatly appreciated. |
the peice that goes on the latch side is the same piece that runs from the vent window back and down its number 13
ok thank you so much, that make much more sense now. mine were all damaged and broken, that what i thought it was a separate piece. now i can order my proper parts
no problem glad to help out
3 Attachment(s)
More pictures to come....made a few changes to engine
Attachment 844101 Attachment 844102 Attachment 844103 |
now that there is a beautiful truck thanks for the pics and hope you get the window seals done
thank you, work in progress. and yes i was able to order all the right parts and should be here soon.
i know how the work in progress is lol going on nine years lol but its drivable now to run for the summer and work bugs out and make the list of changes before i do the tear down and complete build
yea, ive been havin a wicked whine/metal griding at 35+...i think its in the rear end, but idk yet gotta put it on blocks to figure out where its coming from exactly. as soon as i it 35 its loud then dulls out but still there...as soon as i let off the gas its gone, then back wen i gas again...after i drop less then 35 its gone again...i was thinking rear end or torque converter...???? any ideas?
to me sounds like a bad bearing some where rearend would be a good place to start
2 Attachment(s)
Attachment 844241
Attachment 844242 Before and After...still more work to be done too...but its the little things that help change the looks |
Very good looking truck!
Sorry I missed your other posts but looks like 454 has you covered. Glad to have you as a friend also. Get a gasket for your rearend, some gear oil and pull the cover. Check for chipped teeth etc., also write down the stamped numbers on the gears (you might need that later...tells you what the ratio is). Let us know what you find. |
When you go to install the new window channel start up at the wing window and work your way down, you can roll the window up out of the way when you get down into the door, I take the glass and regulator out when I do mine, it's easier that way. Wear long sleaves to work in the door, the lip on the opening is sharp. I use white grease on the channel after I put it in so the window rail slides up and down better.
hey thanks reno, that will help alot when i start. ive already got the inner door tore apart cause im replacing all the tracks and regulator with new parts. everything was so rusted out.
