Original Bench Seat
Can someone shed light on the rod that goes between the release handle and the pass side track on a 68 bench seat ? mine is missing and I would like to get mine working right. What can i use to replace the thing that allows both tracks to move together when you want to adjust the seat back and forth.....thanks
Re: Original Bench Seat
From what I've seen, by 1972 they were using wire instead of the rod. You'll want high strength wire.
Just reuphplstered my 72, it is a length of stiff wire with a hook on each end and a retainer clip.Mine broke off so when i redid the seat I replaced it with a length of cable about 1/16 in diameter adn used a couple of extra hog rings for guides.
what kind of wire do you look for? thanks
Something with high tensile strength, not mechanics wire (soft). Look for tempered wire such as music wire. Also maybe just use a small cable like mentioned above.
I got a piece of 1/8" round stock from the hardware store, bent hooks on both ends, but left room to incorporate a turnbuckle into it so I could maintain just a little tension. This made the lever pull positive, and stopped any potential for rattles. After all of that, I put the seat in the full back position and haven't had any reason to move it since.
