Code PO128
Can anyone tell me what to replace to make this code stop? 2001 Silverado 4.8
PO128: Coolant temp below Thermostat regulating temp |
Re: Code PO128
Replace the thermostat. This dtc sets if a predetermined amount of time has gone by and the coolant temp is lower than the thermostats rating. The tstat is sticking open or opening to early. Very common on newer cars.
Re: Code PO128
Re: Code PO128
Bad temp sensor if the t-stat been changed
