67 Speed Warning Dash
Picked this up the other day, and I know a little about them, but no idea what it's really worth. The strip on the back is dated 66 (hard to see in photos). Seems like the speed warning set up has to be cleaned because the knob doesn't move like it should, but the needle will still go up and down.
Needs a new knob for the adjustment, and it didn't come with the wiring or the buzzer... Kind of on the fence as to sell it, or put the speed warning in my tach dash. Any help is appreciated, thanks http://i248.photobucket.com/albums/g...62/dash161.jpg http://i248.photobucket.com/albums/g...62/dash164.jpg http://i248.photobucket.com/albums/g...62/dash165.jpg |
Re: 67 Speed Warning Dash
I would put that in the $200-$250 range. To make that work in your tach dash you will need to either find a speedwarning/tach tin, or try and remove the brass pin and relocate on your tach tin. I don't think option 2 is easy. It would look good at my house...
I think the pin simply grounds the buzzer, but I could be wrong. If it does you could certainly come up with other ways to get the job done, of course it wouldn't be "stock" but it would function.
