77lesabre 61 Stepside
4 Attachment(s)
My 1961 project, Can't wait to do more work to it!
Former Texas truck. 1976 350 chevy truck motor with 4 barrow Q-Jet carb. 700R4 Trans. Power steering. Front Disc Brakes from Classic Performance Products,Inc. 2” Drop Spindles. All new Rear brakes. New master cylinder and brake booster. Replaced the balljoints and the tie rod ends. New Battery and Alternator. Radiator has been rebuilt. Attachment 1026336 Attachment 1026337 Chevy 350 Attachment 1026338 Front Disk Brake Conversion from CPP Attachment 1026339 |
Re: 77lesabre 61 Stepside
Welcome aboard, you'll love it here. Looks like some nice upgrades!!
Looking good. Welcome aboard.
Posted via Mobile Device |
Welcome!
I thnk the next time I do a front brake conversion I will use a kit too.
Cannibalizing an older model truck is fine, but then you have to remember what year the donor was to get correct replacement parts. |
2 Attachment(s)
Been slowly acquiring parts and working when the weather permits. Recently picked up some steel wheels that are going to be blasted and repainted tomorrow. I got some rear Jeep coil springs that I painted and are ready to be installed
Attachment 1061847 We had an unseasonally warm day last weekend so I stripped the interior and have it prepped to install sound deadner(just waiting for it to arrive). I have new door handles and wondow cranks. Since the seat is out of the truck, I decided to wrap it with Serape's(mexican blankets) Attachment 1061855 |
Welcome to the board, looks like you are off to a great start!
Great job on the seat cover. Looks awesome.
:welcoem: aboard... great start, enjoy this corner of the web, awesome people and a wealth of info here.
5 Attachment(s)
Got some descent weather so I was able to get some work done on the truck this weekend! Installed the Peel & Seal throughout the whole cab, I still plan to do the inside of the doors, but need to order another roll.
Attachment 1073731 I used an app on my phone(not the most accurate, but good for comparison) to check sound levels of the truck at idle before and after the sound deadener. Before: Attachment 1073738 After: Attachment 1073739 I reinstalled the bench seat with the serape covers and love the way it looks in the truck. Attachment 1073737 I recieved and installed my new glove box insert, gas pedal, door handles, window cranks, taillight lenses and drivers side mirror. I also swapped out the stock rear springs for a set of Jeep Spring! It is still not as low as I want, but its will hold me over until I get an adjustable suspension. Attachment 1073740 |
2 Attachment(s)
Got my steel wheels back from media blast and paint this week, time to get some wide white walls and baby moons mounted on them!
Attachment 1077334 Attachment 1077335 |
nice!
3 Attachment(s)
Not much work happened to my truck this summer due to just enjoying driving it and preparing parts for the winter rebuild. I dropped my truck off to my buddy at Bonified Customs last night to get it ready for the Porterbuilt Front Drop member, Custom rear notch and four link, airbag install including Accuair air management. I'll have pictures to post of the tear down soon and hope to have it on the ground early next year! Engine will be getting pulled for the dropmember, so I'm sure there will be plenty of cleaning and dress-up of it as well.
I'll be watching this one for sure. I love the Baby moons.
Good to see more updates...
Got the following teaser pic from Bonified Customs! Looks like I will be going to clean up the engine a little bit more while he has it to install the Porterbuilt dropmember.
Attachment 1340648 |
Another teardown picture
Attachment 1340909 |
I stopped down there today. Your truck is super clean. Pays to have a good starter. Looking forward to seeing this thing slammed. Love that hood also. Made me want to steal it. Haha
4 Attachment(s)
Finished the rest of the tear down to get ready to install everything! I'm Still undecided on what I want to do for frame color/look, but I better make up my mind soon!
Attachment 1345112 Attachment 1345113 Attachment 1345114 Shop Cat Supervising! Attachment 1345115 Started mocking up the Dropmember and control arms, but realized I need to order the newer style spindles, so I called CPP and ordered them...just waiting for them to show up.:banghead: I didn't take any pictures of this yet, but i'll make sure to get some soon! |
Nice progress!
looks like this will be killer truck, i will be following this
5 Attachment(s)
Still waiting on the new CPP 63-70 drop spindles to show up, but Dave at Bonified Customs has been busy working on a few things that needed fixed.
The frame had a hole in it from the old steering system, so he welded in some new metal. Attachment 1349126 The top bag mount was 3/4" to far back so the bag was not sitting straight and causing it to compress at an angle. Sorry for the bad picture, but couldn't really get a good angle to show the issue clearly. (Bag is old and just used for mockup) Attachment 1349121 We are using Firestone bags instead of Slam Specialities or Air Lift Dominators which was causing the bags to rub on the lower arms. Attachment 1349123 Dave cut off the upper mounts and moved them forward to fix the angle issue and drilled new holes to center the bags on the lower control arms to fix the rubbing issue. This looks much better and should make the bags last must longer in the future! Attachment 1349124 This is just a pic of some cool things I have received this year to hang as decorations. Trucks will be painted or powder coated to match mine! Attachment 1349127 |
