Woodgrain vinyl removal
I have a decent set of door panel inserts for my 72 Cheyenne that I want to restore but am unsure of how to start by getting the old vinyl off it chips but not very much so I was wondering if there is and old trick of the trade to getting this stuff off? Thank you for any help/advice
Posted via Mobile Device |
Re: Woodgrain vinyl removal
Woodgrain vinyl decal or woodgrain pattern on vinyl upholestery? A pic could help with answers if possible.
Eather way I would guess it could come off by using a heat gun (carefully) to loosen the adhesive. Then you could peel it off in sections. |
The vinyl decal in the door panel inserts themselves sanding has worked so far today but thy could be tedious I asked another member and he also suggested paint remover to get it down to bare metal like I want
We put ours in a blast cabinet and stiped them then primed and painted.
http://i13.photobucket.com/albums/a2...Picture095.jpg |
That looks amazing Tim I'm going something similar to Ostander's process of sanding them with varying grits but instead of wood grain replication ill be going with a simple semi gloss or even somewhat flat black with polished trim in the process of hand sanding the vinyl of now
