Help need to Drain saddle tanks on dually
I have a 78 lowered crew cab dually and I need to drain the saddle tanks in it as well as the fuel lines what's the easier way to go about this as I don't want to plug up my rebuilt carb and new fuel pump. All advice and techniques welcome.
Posted via Mobile Device |
Re: Help need to Drain saddle tanks on dually
I've done it on a different vehicle by using an electric fuel pump i picked up from the parts store. Hooked it up somewhere before the pump and filter on the vehicle, ran a tube from the pump to a drum. I ran the electric fuel pump off a car battery. Wrapped the electrical connections good and kept the battery a safe distance from the fuel/fumes.
I've heard of that one too you have an idea of what the pump cost you? I'm sure mine has a lot of crud in the bottom if the tanks so I'm not sure if I should try and drop them at this point.. Which would be a pain but It could be done.
I think the pump was 15$ or so. I have done it by snaking a tube inside the tank too, its kind of hard to determine if your at the bottom of the tank though. I suppose a coat hanger tied to the tube could be of some help.
If your worried about crud you better just bite the bullet and clean them while your at it. Espescially with the new carb. Posted via Mobile Device |
Alright so get the gas out first with a pump then drop the tanks what can I do to flush them obviously water make the rusting worst and I'm familiar with coatings that you can swish in your tank but getting the crud out is priority
Most common method is about gallon of acetone and a foot or so of medium sized chain. The chain helps knock the scale off. Tie something to the chain so its easier to remove from the tank. Seal off the openings and start sloshing.:lol:
Whew buddy that'll e a big tank to slosh
I wont have too much fuel in it hopefully any suggestions on a brand of electric fuel pump?
Perfect ill look into a couple places tonight and hopefully have empty tanks by this evening thank you
What are you trying to get out of the old tank. Old varnished fuel, crud in the tank?
