Upper Radiator mount (where?)
Hello: I am looking for the bracket that holds the radiator on the top. I already have the U-shaped mounts from the bottom with the pads but I can't seem to find the one from the top ANYWHERE.
Specs: 1965 C10 with a new Champion 2row radiator. I found a picture of what it should look like (from TR65 I think). I have seen them around in this forum but I can't find where to buy them. Junk yard? |
Re: Upper Radiator mount (where?)
5 Attachment(s)
You might need to custom fabricate your if the top of the radiator has a different thickness than the original Harrison radiator.
The original top support has 2 U shaped brackets with rubber inserts. These are spot welded to a flat plate with the proper bends. You could make one up easily enough if you have a metal brake and a welder. True, buying a salvage part would be easier. The pic below are for reference and should be correct for a 1960-1966 C10 with a short-wide V8 radiator and the last photo is for a tall-narrow L6 radiator. |
There are 2 different upper radiator hold downs as well as the lower saddles for the V8 radiator. There the ones for the 2 and 3 row core radiators and a wider one for the 4 row core radiator.
I have an extra top part, I also have a champion and mine fit well with some trimming of the rubber or you can use a thinner piece of rubber( this is what I did).
If you want it, Ill place a for sale in the parts section. |
I have a top mount. If interested, give me a holler.
3 Attachment(s)
is this what your looking for? if so send me a pm
thanks for the input guys but I decided to go the route of sheet metal from home depot to bend it up.
Sounds like a much cheaper idea! Please post some pics of your finished product. I'd love to see it.
